Help - Search - Members - Calendar
Full Version: steering sometimes stiff
LR4x4 - The Land Rover Forum > Vehicles > Defender Forum
dan9090
my power steering is sometimes very stiff (usually with the steering dead central, no turn on).
fluid looks ok and i replaced pump not long ago. Looking underneath I noticed that the track rod (i think) is VERY close (if not rubbing) on the top of the small guard that extends down off the front diff.
would this cause the steering to be stiff? if so what might have caused it to come closer to the guard?
mmgemini
There are two u/j's on the steering shaft from the steering wheel to the steering box inside the engine bay.
Lubricate well with WD40 then with oil.
These should them free off.
A common occurance.
mike
western
take the diff guard off, onlt 2 bolts, removed mine ages ago, lube the column joints too.
dan9090
thanks both.
western - does the guard have any purpose?? also - do you happen to know spanner size? (truck is elsewhere and dont want to take my whole kit)
western
IIRC the bolt heads are 9/16 inch across flats, it does have a purpose but doesn't protect very well.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
