jack54turbo
Nov 16 2008, 08:32 PM
hi guys dummy here( yet again!)
i have a 1996 defender 90,which up untill recently, i thought it was a 300tdi with an r380 transmission.
but when i had some transmission issues! and took it to peices-i found an lt77 box!!!!?
whats going on lol is this normal or has my vehicle had an engine or a gearbox replaced it has done 203k!
cheers guys(again!)
jack
western
Nov 16 2008, 08:56 PM
if the engine has a vee belt to drive the water pump/alternator/power steering then it's a 200Tdi, if the turbo is above the manifolds it's a Defender spec 200Tdi, if it's below the manifolds and has a multi groove drive belt on the water pump/alternator it's a 300Tdi.
Mo Murphy
Nov 16 2008, 09:00 PM
Jack, what position was reverse in on the gear stick ? To the left of first and forward is LT77 and straight back from 5th is R380. That should tell you what you have.
Easiest way to tell the engine is that the 200 has a "V" belt on the front whereas the 300 has a wide flat ribbed serpentine belt.
HTH
Mo
jack54turbo
QUOTE (western @ Nov 16 2008, 08:56 PM)
no v belt, and turbo is below manifold.
was this engine and gearbox combo(300tdi and lt77) a common occurance?
thanks
jack
jack54turbo
Nov 16 2008, 09:08 PM
QUOTE (Mo Murphy @ Nov 16 2008, 09:00 PM)
HTH
Mo
hi mo
reverse is back right, and the belt i a flat belt,
is this engine gearbox mix common?
ie, 300tdi on lt77?
also mo do u know!? if i will get a great deal of gain by fitting a disco transfer box to my defender?
thanks
jack
LandyManLuke
Nov 16 2008, 09:14 PM
QUOTE (jack54turbo @ Nov 16 2008, 10:08 PM)
So you've an R380 then...
muddy
Nov 16 2008, 09:15 PM
Thats a 300 and R380 then
western
Nov 16 2008, 09:23 PM
I concure with my fellow members above, defo a 300Tdi/R380 combination, so all standard fit in a '96 vehicle.
jack54turbo
Nov 16 2008, 09:46 PM
it looks like an lt77
Click to view attachmentim confused, sorry to be a pain guys!
western
Nov 16 2008, 10:13 PM
a long shaft R380 to me, in this pic on the gearbox right hand side [opposite where i've marked] is the serail number if it's a r380 it'll start with 56A******, if it's a LT77 it'll start with 50A*******
the_mouse_man
Nov 16 2008, 10:19 PM
western
Nov 16 2008, 10:21 PM
to late/wet/dark to go out now
Mo Murphy
Nov 17 2008, 12:20 AM
Jack, regarding the transfer box, it really does depend on what you are using the 90 for. If lots and lots of motorway miles then, yes it would be worth it but otherwise you may find the gearing a bit too high for town/country use especially if you want to fit larger tyres at sometime in the future.
HTH
Mo
jack54turbo
Nov 17 2008, 08:37 PM
QUOTE (Mo Murphy @ Nov 17 2008, 12:20 AM)
HTH
Mo
thanks allot mo!
allready got 35's! on her and i only do motorway to wales and scotland wonce or twice a year.
so better to stick with standard?
thanks again
jack.
JST
Nov 17 2008, 08:52 PM
running 35s i would stick with a 1.4 box unless you like changing clutches alot and have a heavily tweaked motor
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
