QUOTE (Drizz @ Nov 19 2008, 07:44 PM)
Cock! Ive welded a new floor in without inspection cover LOL. Out comes the angle grinder tomorrow then!
Before you get very dirty & do a lot of hard work - try the easy bits first.
It could be simply that the fuel filter under the bonnet is LOOSE, OR FULL OF DIRT/BLOCKED,
OR LOOSE UNIONS SUCKING AIR.
You could bleed the injectors also & see if they are full of air.
The lift pump is easilly checked by loosening the union at the side of the under bonnet fuel filter - AFTER - you have run engine for a while re-creating the lack of power issue, then loosen the union.
If the lift pump works, fuel will splurt all over the place. . . . . .have a rag handy, you only have to crack it open a turn or so. . . this will happen provided the fuel can get there.
I'd check the crap trap under the fuel tank/ boot floor first.
If you try to drain/empty the crap trap under the boot floor, don't bother to drain it with the little screw flap - it will likely break off, just remove the whole bowl - 10/11mm bolt under centre.
You may find that it is full of jelly from the veggy oil in most pump diesel now - I had this problem.
Good luck, hope you get rolling again soon.
Filthy
