QUOTE (disco_al @ Nov 17 2008, 01:34 PM)
no, i may have mislead slightly,
, in that it is behind the headlamp panel, where the jack sits. IIRC i have seen them on RRC's as well.
it looks like a large tennis ball.....
It's called a Vacuum tank (a ball with a pipe in and one out) and used inconjunction with the heating system up to VIN LA067123. You can position it anywhere in the engine bay.
As per
Ivan above the heater flaps are controlled by vacuum.
