QUOTE (Raceface120 @ Nov 18 2008, 08:57 PM)
If you mean for the gauge then it's on the stat housing.
Pete.
This sensor is specifically to do with the EGR valve for cylinder head & exhaust temperature sensing.
If you have blanked off the EGR valve, you can dissconnect it or insulate the wires & leave them in situ, remove the electrical module with the air pipes leading to it - module is next to the wheel chock & jack on near side inner wing at front.
Block off all the little black pipes & tie them out of the way.
Performance will not change if the EGR is blanked off. May improve a little with the above.
You MUST block off the little black pipes/tubes or water could get sucked into air filter or engine.
I simply used M4 x 10mm bolts pushed into the rubber tube ends.
Job done.
Filthy
