QUOTE (martinspragg @ Nov 18 2008, 11:48 PM)
There are 4 yellow plastic relays and one metal relay under the fuses engine bulkhead inside the cab. I assumed it was the relay but it could be something else, there is definitely 0 volts at the ignition switch connector that provides power to the glow plugs.
My other option is to rig a push button switch which will manually provide power to the plugs on cold start, I did this on an old chevy I had and it worked a treat.
Martin
hi,
As far as i understand it, the NA didnt have a heater plug relay. All the current went through the ignition switch. (Well my ExMod was this way). Because of the high current involved any sort of resistance would give problems.
I solved this problem by wiring in a seperate high power relay directly from battery(Fused with a Maxifuse) and used the output from the ignition switch as a trigger for relay.
Dont mean to be patronising but i take it you are holding the key turned onto the springy part of ignition switch slightly to heat plugs.
(I didnt know anything about this for a long time so no bones there).
All bits i got were from VWP.
You will soon know when you got the plugs working as the NA will be so easy to start. Bet at the moment it is a real b!!
Hope this helps.
