QUOTE (David Sparkes @ Nov 18 2008, 06:46 PM)
Given the comparative prices, you may like to consider fitting a pair of HID bulbs (from HIDs4U) in 2 of those high mounted lights you have there. You solve the tree problem that did for your daylighter.
I'm not saying the output will be as good as a purpose built light, but these things put out so much light that the result may be sufficient for your purposes.
Note 'consider fitting' and 'may be sufficient'. While I do drive behind HID bulbs, I've never driven behind high mounted HID bulbs.
Cheers for the pointer to HIDs4U - I like the idea of this high intensity displacement stuff but it's bl**dy expensive kit!
The rectangular lights on the cage are only cheapo ones - they give more of a flood beam, and can be angled outwards slightly - ideal for the night section on the SCOR Randonee. The daylighters were my long range lights.
Looking at the prices of stuff, I might try and straighten out the casing and get another sealed beam unit for the time being, then look at maybe getting some of
these at some point in the future.
