QUOTE (yellow @ Nov 19 2008, 05:25 AM)
First check your UJs and change them if unsure. (The easiest of jobs I believe) This is the most common cause of rumble.
While you have your rear and front props off, check for play in the diff flanges, as the bearing there could be on their way out. Again, this is a fairly easy job.
Re-assemble everything and take it for a drive. Still a rumble? Start checking the wheel bearings, and while you have the hubs off, check the driveshaft flanges on the rear wheels as well for play.
Re-assemble everything, and take it for another drive. Still a rumble? Could be your transfer box. Or your gearbox.
Be aware that the solution described here goes from 'cheap' to expensive, and from easy to hard...
If you want some one from the forum to come out to you and check for you, I am sure you will have no problem finding volunteers...
Happy hunting
Interesting you mention the transfer box. I was unable to get it into Low while launching the boat on Friday. I meant to drag out the manual and see if I had the right combination of planetary alignments, tranny in right gear, clutch either in or out as the case may be, vehicle rolling or stopped, or in reverse.... we have never used Low Range here, although I vaguely remember checking it out when we bought the vehicle.
I certainly could have used the low gear range to launch the boat. We did manage to get her launched, of course:
But alas, it was not to bein Low range. Do these Land Rover transfer cases freeze in Hi on a regular basis?
