QUOTE (diesel_jim @ Nov 19 2008, 11:39 AM)
They're the same overall dimension and shape (like where the two bolts attach it to the bulkhead)
but i think you'll find the difference is the shape/size of the cut-out in the middle that holds the fuseblock itself.....
early 90/110 had the large glass fuse type holder, then 200tdi's had the blade fuse block (quite large, two rows of fuses)
my Td5 has 2 smaller blade type holders in a row.
Hi Jim,
Thanks for the reply, I assumed it must be something like that. I was planning on making a part to replace the original glass fuse holders with blade alternatives, but if there already available there would be little point!
Your TD5 with 2 smaller blade type holders, how many fuses will that hold? My solution should be able to take 16, 8 per row...2 more per row than my current glass fuse holder..
matt
