QUOTE (LR90 @ Nov 19 2008, 06:04 PM)
Not knowing the tyres or vehicle it is difficult to give a direct answer. You really need to look at the tyre manufactures figures for the tyres in Q and then using your axle weights get a starting road pressure to work from. Chalk test will help you refine this for road use. How much you drop them by for off road (30% is my starting point) again really depends on conditions and what protection you have to stop the beads coming of the rim.
hi,,thanks for reply,,,its a 1990 rrc..and the tyres are bridgestones,,on the wall of tyre it recomends cold pressure of 80 psi,,,i thought this was a little high so ive put 50 psi in them but they seem a little wobbly,,and seems to wonder a little on the road...cheers...
