Help - Search - Members - Calendar
Full Version: Very Sick Disco 300TDi
LR4x4 - The Land Rover Forum > The Lounge > International Forum
filthy
My Disco 300TDi - N reg, had a pretty bad life before I owned it.
Lady owner who loved it, but had no money or any mechanical sympathy what so ever.
2 months b4 I got it, she did her 1st off roading ever & put it down a 16ft embankment (vertically) & straight into a 2m cubed concrete tank stopper, with a railway sleeper cast into it.
On hitting this, the front diff was bent, steering gear trashed, rad/oil cooler/intercooler + pwr steering pump, cam cover, both wings, bonnet, cross member, grille etc destroyed.
Bless her - - - - - she then drove it another 3/4 mile back to the start line where it siezed up solid & was dry of all liquids
It was badly repaired, had a rotten engine rebuild & body job etc.
I bought it, it drove OK ish & in the rain looked good - how wrong I was.
Since then I've been in it repairing or under it most weekends, spent so much time on it, I can't afford to get rid of it.
I've done just about every job on this vehicle that could possibly go wrong under a landrover, even re-tapped / helicoiled EVERY bolt fixing on the cylinder head, even the 8mm crank breather bolt needed doing. Turned out the repair shop had a college trainee do the work . . . . . mmmmmmmm
He must have had one adjustable spanner & a 3lb lump hammer.
After countless engine repairs, a head gasket job, turbo change, rad, intercooler, replaced crunched cam cover, pipes blar blar blar it now goes like the clappers.
I decided to put a 2" lift kit on it - in addition to the problems with the Terra-Firma kit of junk (another topic listed)
I, now descovered that the transfer box was so badly walloped in the crunch above, that the Gear box has a cracked side & the transfer box is not aligned properly on the gear box AND the front output bearing surround has a thin stress crack in the Ally. . . .
Both cracks are above the oil fill level, or I may have spotted it.
She must have hit the tank stopper VERY hard . . . .
So, however hard you look, it is still possible to buy a duff motor - as I did.
problem is that now, I need to get another complete Disco 300TDi for spare parts, so if any one has one or knows of one, I'd be most gratefull. Even if it is just/not road legal, I could break one or other vehicles to build a good one.
Cheers
Filthy
freeagent
If it has been hit so hard that the transfer box and gearbox casings are damaged, i'd say theres a fair chance the chassis might be out of alignment, and the vehicle should have been written off...
I'd be temped to buy an MOT failed disco with a straight Chassis and use that as the base for a build-up.. I'd not be happy driving around in what you've got at the moment..
Mark
as above, it sounds like it got hit pretty hard...
Jericho was breaking a 300tdi in the classifieds the other day - might be worth looking at...
Mo Murphy
I'd be inclined to take the good bits off and throw the rest away, then restart on a vehicle in better condition, like an MOT failure.
Good luck
Mo
WALFY
I heard of a very cheap Disco MOT failure the other day. PM if you require more info and I'll make a few enquireies
V8CAMEL
i am about to put my ES 300 TDI up on ebay 130k miles mot til aug 2009. will start it at 800 squids
PM me if you are interested live near sherborne dorset so not far from you.
paul
filthy
QUOTE (V8CAMEL @ Nov 20 2008, 12:41 PM) *
paul
Hi Paul,
very interested.
Please mail me if you can & I'll pop over, only 30 miles away from Me.
Regards
Grant / Filthy
jericho
Mine is still hanging around. N reg 300 Disco.
See For Sale section for photo.
Axles have gone.Head warped.Front wings,grill panel and headlights gone.
You can have the chassis,body,interior,gearbox and transfer box for £250.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
