QUOTE (Simon B @ Nov 20 2008, 11:36 AM)
Finally committed to oil burning (though my 4.6 is in the shed just in case I dont like it. After I've collected it I can start! Someone did mention I would get the best out of it with the disco ratio high transfers, will have to research this - bit scared of gearboxes!
My 2.8 td zoo zoo pulls very well with the gearing it has. It weighs 1900kg so is heavy. If I were putting the engine in a Landy (which I may) I would use the disco 1.22 Transfer Box as that is slightly higher than the zoo zoo and with the landy weighing less I think that it would suit very well.
If you go 1.4 defender it would be too low, first would be useless and you would be topping out at about 75 flat out screaming (4000rpm approx) with a diesel engine.
Diesels like to pull and mine goes very well pulling easily from 30 in 4th with loads of power so don't be afraid of upping the gearing as with the lighter land rover it will be very economical and go like stink.
I tow with mine and the gearing isn't too high.
Hope to have been of some help
