Help - Search - Members - Calendar
Full Version: Which moddest engine
LR4x4 - The Land Rover Forum > The Lounge > International Forum
Pages: 1, 2
Ben Jordan
Following on from my Ultimate engine post. I have now decided that i do not need a big horsepower engine sad.gif
I need a reliable engine that will produce a respectable amount of power/torque and last quite a few years, The money i then save over a higher spec enine can then be spent on axles etc. biggrin.gif It should be transferable between land rovers but i cant see this as i problem if it fits into one of them. I will be covering about 5000 miles a year tops with the odd occasional long trip and it needs to be able to deliver the goods off road. I have put my suggestions in the poll above smile.gif
I would like the engine to be new or rebuilt to a standard better than new.
minivin
Go 3.9V8, enjoy the V8 till it becomes socially unacceptable to own such a vehicle biggrin.gif
Ben Jordan
QUOTE (minivin @ Feb 11 2006, 02:16 PM) *
minivin
QUOTE (Ben Jordan @ Feb 11 2006, 02:25 PM) *
gelf
lets be honest.......... if owning a V8 means 20degrees C sunshine in the middle of January....then im sticking with my 3.9. laugh.gif
Ben Jordan
If you vote you have got to give your reasons for it, So i can understand the logic of your decision biggrin.gif
gelf
big yank...NO i have a friend doing this at the moment and is having alot of problems, heavy and keeps over heating, and the gearbox wont last.
jap... YES isuzu engines are ment to be really good for 500k.
V8 .... youve already got one so get it rebuilt......cheapest option and probably get the best power.
others
too expensive unless youve got alot of money.
western
300Tdi, simply cos their easy to own, take care off & don't have any really nasty faults that haven't beebn dealt with, parts easy to get hold of & lots of info around.
mr_wuffles
You forgot the 200 Tdi the better version of the 300 Tdi you know the version of it that doesn't break? rolleyes.gif
white90
200-300TDI both fine work horse engines.
the 200 more rugged 300 slightly more refined once the cambelt issue is sorted the rest is great plus being newer, lower mileage looked after examples will be easier to locate.
Steve Hiatt
QUOTE (gelf @ Feb 11 2006, 03:42 PM) *
With the correct cooling it won't overheat. It's an installation problem not a problem with the engine.
Will run OK with a standard LT95 gearbox, otherwise you need to upgrade.
Not exactly modest
Ben Jordan
QUOTE (western @ Feb 11 2006, 03:54 PM) *
white90
yours fixed yet?
Ben Jordan
QUOTE (white90 @ Feb 11 2006, 05:19 PM) *
yours fixed yet?
Nope. But to honest i dont think the problem is with the engine.
western
QUOTE (Ben Jordan @ Feb 11 2006, 05:14 PM) *
honitonhobbit
QUOTE (mr_wuffles @ Feb 11 2006, 04:15 PM) *
Exactly - the 300 Tdi is gay
mr_wuffles
QUOTE (honitonhobbit @ Feb 11 2006, 07:38 PM) *
Ask frida turner which ones always go poop and she'll say 300 Tdi. 200 Tdi engine is better for the price of a International HS 2.8 TGV you could get a re-con re worked 200 Tdi that would be bullet proof ph34r.gif
LR90
Not seen mention but isn't there an Iveco engine alternative?
FridgeFreezer
3.9 V8 - they're still the cheapest, and given the % fuel you'd save going diesel it's not worth changing.
Parts are cheap and plentiful and every LR has at some time or another been V8. The V8 has plenty power and flexibility. Sorting the usual Lucas gremlins (vis MS'n'S or whatever other method) will help reliability, power/economy and help with waterproofing too.
Worst case scenario you kill the V8, 5 minutes and £150 later on eBay you can have a perfectly servicable 3.5 engine ready to drop in to get you going. TDi's are getting cheaper but they're not that cheap and won't be for a long time.
white90
The 200 is more agricultural and tougher
the 300 more refined
with so few differences.
the 200 will stand less boost increase than the 300
I'd rather have either of these two than a foreign jonny engine.
I got a 300 as I wanted a late 90 and so far it has proved a decent engine.
with only a few oil leaks and a turbo rebuild after 130k all is going well.
for the ££ the V8 is a cheap option and probably the best idea
Bush65
I'm biased to diesels - I've had my share of Rover v8's, the last was a 4.6 in the rangie.
The 200/300Tdi aren't bullet proof compared to a light truck diesel.
The 4 cyl diesels from Isuzu N series trucks and the Toyota Dyna are great engines that will fit into a Rover. They have great torque from idle, are very reliable and long lived. But I wouldn't use either with Rover drive train.
jjojjas
voted for 300tdi as I couldn't find 200tdi on the list.
reliable, simple, and less parts than the 300tdi to go wrong........
Of course, If you had asked for a "civilised" engine my answer would be different.
Jas
istruggle2gate11
Well I voted for the 300tdi.
Strange from a guy who loves V8's!
Reason: If I was starting from scratch on a car that was going to be relied upon for regular road use then I would go for the coughs and sneezal.
The only reason I dont have a squeezal is ....I love V8's (boy hood dream etc), Ive got 5 very good V8 engines to play with (3.5 x 2, 3.5 turbo, 3.9 rebuilt, 4.0 blue printed) and they are in my toys.
If I had to rely on my off roader for road use, no way would it be the v8, expense would stop that instantly.
minivin
Does sound like we are getting back to the "my heart says V8, but my head says Diesel" smile.gif
Steve H
2.8 Isuzu, front mounted intercooler & tweak the pump the same as the 200 & 300 TDi pumps ( they're virtually identical), even better get one from a Vauxhall Frontera, they've got the bigger turbo & a FMIC already, perfect with a Rangie drive train. Jez would say that the cam belts on these are easy to change & so they are but if you can get one with timing gears rather than belt you're home & hosed, look for metal domes on the front rather than flat ribbed plastic cover. No hassles with water ingress while wading then.[Helmet & flack jacket]B....y site more reliable than anything LR ever made. [/ naaah!, I'll just keep them on ph34r.gif ph34r.gif
Actually, if it weren't for the cost, the 2.8 TGV is probably the best way to go, getting an awesome reputation around the world, shows what a Land Rover engine could be like if it'd been done properly.
Cheers, Steve
webbsite
QUOTE (Steve H @ Feb 12 2006, 06:42 AM) *
Cheers, Steve
anybody got any views on the Isuzu 3.0TD there are lots of them here in Riyadh
Ben Jordan
QUOTE (mr_wuffles @ Feb 11 2006, 07:16 PM) *
My mate has owned the 200tdi and 300tdi and has advised me to stay well clear of the 200tdi, as they are a bitch to work on compared to the 300tdi.
Ben Jordan
The problem with me changing to 300tdi is i wont be able to use my nice V8 auto unless i have a conversion plate. Then i don’t think they would work to well together would they?
Steve H
QUOTE (webbsite @ Feb 12 2006, 09:29 PM) *
If this is the 3.0 DOHC diesel from the 98 & later Troopers & Wizards etc, its a real grunter of an engine, 156hp standard, but also has some real reliability issues. Do a search for Isuzu 4JX1 motor. It would blow most Landie trannies to bit, Might be OK in an E38 Rangie though. From about 2002, the 2.8 (4JB1) was replaced by a 3.0(4JH1) derivitive of the 2.8 with electronically controlled injection, ( like the later 300TDis in autos I think), this is a pushrod OHV engine same as the 2.8 though, still gives about 130hp, but not the same low torque as the Landie diesels. I've a mate who has one in a Rodeo & tows his boat over steep hill around here no probs.HTH
Cheers, Steve.
Turbocharger
Much as it hurts for me to say it I don't think the cost of a diesel is justified here, for 5000 miles a year. If you don't mind using WD40 on a misty day, get a cheaper (unit cost) petrol V8.
Ben Jordan
QUOTE (Turbocharger @ Feb 12 2006, 10:58 AM) *
If im going to stay V8 then i will have my engine re-built.
Ben Jordan
Looks like its between the V8 being re-built and a 300tdi.
I guess a good V8 rebuilt to cost about £2.5k, What is the going price for a new or re-built 300tdi?
Hybrid_From_Hell
QUOTE (Ben Jordan @ Feb 13 2006, 10:04 PM) *
eh ?
Why ?
Nige
Ben Jordan
QUOTE (Hybrid_From_Hell @ Feb 13 2006, 10:29 PM) *
eh ?
Why ?
Nige
Because i know thats what other people have spent getting the same spec engine as im after.
Hybrid_From_Hell
Hi ben,
was just shocked
to rebuild a 3.9 even improve on it 2500 is a hell of a lot of money ??
Price up what your thinking of ?
Often a regind, set of shells, big and small ends, then cam, full balance, new rings deglaze etc etc is a fraction of that ?
What was £2500 ??
Nige
Lara
Have just voted for the Rover V8,
a, it is already fitted so no messing in that department,
b, it is a good light unit,
c, If you think that JE Engineering do all of Bowlers engines with no probs, why shouldn't you,
d, sounds great,
e, go 4.6 and rev it less for the same power and more Torque
f, fit it to an auto box at the same time and you will be in heaven.
g, Deisels are great but they sound 5hit compared to a V8
h, The sound
Lara
FridgeFreezer
For 2.5K I'd want a 4.6 with all those mods on it too.
jules
QUOTE (898kor @ Feb 11 2006, 11:47 PM) *
I pritty much second all that
ihana
while we're on about the 2.8 motor, can anyone tell me the contact details of the place in Netherlands
that imports them?
thanks,
Tom
dollythelw
QUOTE (ihana @ Feb 14 2006, 03:21 PM) *
that imports them?
thanks,
Tom
all round nice guys in Nederlands to be found HERE
I love the sound a diesel makes in water, its easy to hear over the silence of a V8 stranded in a lake...........
Ben Jordan
I think the V8 is going to be my choice. As i can probably get a really good rebuild for the price of a 300tdi with matching auto box and it is less hassle. The V8 all ready has a new gearbox so it would be a same to lose that.
Now when looking for a re-build what should i be looking at having done? I want a bit more torque with a lot more reliability. I am thinking of a general rebuild top hat liners, Properly balanced maybe even blue printed, Some head/plenum flowing, uprated cam and tubular exhaust manifolds?
Not sure on what size engine? What do the builders class as a dynamic balance?
minivin
depends what you are willing to spend, if your thinking blue-print your talking total rebuild.
A Cam maybe your best starting point, check out RPi:
RPi Cams
Also, if you pull the EFi off the top and look into the tunnel, if it's black and gungy your looking at a thorough rebuild, if it's reasonably clean then you possibly got the chances of a good engine to start with, worth it just for a valley gasket
Ben Jordan
I am after a total rebuild, That way i dont have to worry about it ever again biggrin.gif
minivin
QUOTE (Ben Jordan @ Feb 14 2006, 04:48 PM) *
I had that theory once, but then I woke up and remembered I had a collection of British cars and bikes laugh.gif
Ben Jordan
QUOTE (minivin @ Feb 14 2006, 05:11 PM) *
I dont have that problem. Im getting a company car with a pay rise this year as well biggrin.gif
minivin
QUOTE (Ben Jordan @ Feb 15 2006, 06:18 AM) *
<monty python mode>
You lucky lucky ba$tard!
</monty python mode>
Hillbilly Raider
We have a company car and it aint the perk it used to be( taxed to the max)
And with running 2 LRs as well, the extra money dont go far!!
Ben Jordan
QUOTE (Hillbilly Raider @ Feb 15 2006, 01:02 PM) *
Im not on a bad wage, I afford and run two Land rovers quite comfortably, Used to have four cars on the road between two of us until recently. And as for the company car i pay no tax, the fuel is paid for, infact im getting paid for the privilege biggrin.gif
Hillbilly Raider
Lucky you! we thought about the "opting out" doda , you know leasing a car for work use only.... was just as damed expensive!!! when you do about 30,000 miles a year.!!!!
Ben Jordan
QUOTE (Hillbilly Raider @ Feb 15 2006, 05:02 PM) *
I am lucky. My car is free but only for work purposes (you wouldn't want to be going down to the supermarket in it anyway wink.gif ), that’s why i still need the Rangie but it will be doing very few miles.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
