Help - Search - Members - Calendar
Full Version: On-board MIG welder project
LR4x4 - The Land Rover Forum > The Lounge > Tools and Fabrication
MogLite
This is what the postman turned up with today
Bought of ebay US for $100 posted - cost me another £17.50 in duty and stuff, so a lot cheaper than the equivalent Ready Welders
With a spool of flux wire (it won't take gas) and 1,2 or 3 12V batteries, I should have a MIG welder I can use in the field smile.gif
There is a wire speed control, but no power control, so some experimentation with wire speed and number and quality of batteries will be necessary.
There are two electrical connections, a power connection, and a smaller one which I assume is the earth for the wire feed motor.
Alas it didn't come with tips or a shroud, but I believe the Tweco stuff is resonably easy to get hold of.
Be a useful thing to have around I reckon.
marcus
why mig? tigs gotta be better but not as cheap granted.
MogLite
QUOTE (marcus @ Feb 17 2006, 11:45 PM) *
northernchris
By the look of moglites truck it has been Migged together anway!!! biggrin.gif
marcus
because it looks like that little thing would stick fag papers together laugh.gif you can get a lovely little tig plant no bigger than a car battery that'll push 160.expensive though.Plus i'm a tig welder and i've got a few in the workshop!
MogLite
QUOTE (marcus @ Feb 18 2006, 06:33 PM) *
Why do you say that ?
Its only a spool gun. Surely it depends on what power source you hook it up to. ie 1,2 or 3 vehicle batteries
marcus
i'm sure you'll get it going good.power source is all important as you know let us have an "in the field use shot !"
LR90
What are the options for battery powered tig?
And what about just carrying some manual metal arc rods and using them with a set of jump leads? Not as easy to use but cheap and compact.
marcus
stick leads work for me LR90.the mans got a mig though!Altinator power for the TIG i think.Stick leads are very easy and cheap as you said,gotta be able to weld especially in a muddy hole!
white90
PPW
These look good.
££ but good
northernchris
IF you are talking about inverter tig sets yes they are small and no i wouldnt say £150-£200 for a 150amp scratch start tig IS dear? dry.gif
I am also a TIG,MIG,MMA and gas welder! (with £1000,s worth of welders in my own workshop)
Chris
PS the pic is only of the spool feed for the mig.
MogLite
QUOTE (LR90 @ Feb 18 2006, 06:57 PM) *
Trev - arc rods are a possibility, but my arc welding isn't up to much sad.gif
However - you need different rods for things like axle cases etc.
With arc, to weld an axle case, you'd have to preheat it, weld it with a fancy rod, and then insulate it to allow it to cool slowly.
Not really practical in the field
marcus
Eh northernchris you sure your not a southerner? £200 up north could buy you a plant hire company!!!
I'm also well versed in all welding disaplines but have found that i'm a natural TIG welder....expensive,unable to work in the cold and like working in breweries and chocolate factories!
I've read somewhere about a high output amp for car stereos that will put out 150 amp,more than enough for mig,tig and mma.
Lovin this thread.
dollythelw
its a DC welder, can be used either with 24v car battery as a power source or as a spool gun for a mains powered welder - hook it to a TIG and have MIG facility,
For in the field use you can't beat em, they are easy to use and the ready welders I have handle 275amp at 60% on flux cored or 100% with gas, hot start ones are less fun to use but cold start is childs play
They also MIG ally quite happily
Andy - Ive got some tips that should fit yours, sort you out when you bring the box up
simonr
Andy - that looks fab!
I'd looked at these in the past but ruled them out as too expensive - but yours looks promising!
I've experimented a little, stick welding with my jump leads. The reason most people go for 24v isn't so much for the higher current delivery, it is that it is less effected by rust & crap on the surface.
If you are welding clean metal, 12v works fine. I reckon it was delivering about 80-100A on 12v with 2.5mm rods.
Mig would be wonderful by comparison!
Si
Astro_Al
Andy - I think I've got a 5kg roll of ali and a little tank of Argon (with tube adapter) knocking around if you want to give it a try with that? If it works, I might even have a job for it!
Al.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
