As most of you will know. I am after another more substantial engine to put into my range rover and at the moment the 3.9 sat in it has a snapped spark plug. The new better engine will not come until i have moved house so a bit off yet. To get the Rangie back on the road for the short while i am considering removing the head having the plug removed and replacing the head. The downside of this is the gaskets and studs are going to cost a fair bit from what i have seen it will blow a big hole in £100. The engine has probably covered 142,000 miles and i am scared of what else i will find that needs replacing when the head comes off. Or i can buy another V8 and put that in. i have found a 3.9, which should be a straight swap, a 4.2 will that be a straight swap? And a 4.2 supercharged not to keen on this as i have herd the super charger does not deliver an even mix of fuel/air to the cylinders, Is this true?)
What do you think is going to be the easiest/best option?
