mpb
Apr 24 2006, 09:02 PM
ALL NON TECH REPLIES WILL BE DELETED TO KEEP THIS THREAD ULTRA USEFULL !
Was thinking it would be good to compile a list of tool sizes for specific jobs.
So here goes:-
Hub Nuts - 52mm Socket
R380 Filler Plug - T55 Torx
R380 Drain Plug - 32mm Spanner
LT77 Drain Plug - 24mm Socket
LT230 Transfer Box Drain Plug - 17mm Socket
Ajlorton
Apr 24 2006, 09:39 PM
Good thread!
Radius arm to chassis nuts = 30mm socket
Radius arm to axle nuts = 24mm socket / spanners
I hope I've got those right!! I'm pretty sure that's what they were on my defender. Now I'm wondering whether that's a universal size for all coiler LRs!??!
geoffg
Apr 24 2006, 10:14 PM
2.5 NA crank pulley nut 41mm
dirtydiesel
Apr 25 2006, 12:49 AM
Steering box drop arm nut 1 5/16", no idea what that is in new money.
istruggle2gate11
Apr 25 2006, 12:10 PM
QUOTE (dirtydiesel @ Apr 25 2006, 01:49 AM)
1.3125" or 33.3375mm
JST
Apr 25 2006, 08:51 PM
wheel nuts 27mm
wheel station to axle front - 14mm closed end ratchet spanner fits well despite different head.
dirtydiesel
Apr 26 2006, 10:07 AM
swivel to axle bolts on a late coiler, the ones with the 14mm(9/16) double hex bolts.
Another sugestion would be 14 mm double hex socket for later brake discs.
And a really good quality (cos they round off easy) 13mm double hex socket for later brake callipers.
jonboy
May 3 2006, 10:17 PM
Thread size for slider type diff guards on disco - 3/8 BSF.
jules
May 4 2006, 12:19 PM
Freelander cv/hub nut 32mm kin tight
Freelander bleed nipples 11mm /14mm
full set of star thingy's toques needed as props held on them as is steering rack.
ball joints 19mm
steering rack joint 19mm
steering rack star things
engine mounts throw away and build your own.
wheel nut for freelander 22mm
Rear Axle Ball Joint - 30mm Spanner
Phil Hancock
May 8 2006, 05:49 PM
Series hub flange bolts 3/8"BSF or 19/32"AF.
" Half shaft nut 5/8" BSF
" Spring Shackle bolt 13/16" AF
" Spring Shackle nut 7/8" AF
" Metric U bolt nuts 19MM AF
white90
May 9 2006, 05:29 AM
freelander oil filter housing 36mm
simonr
May 10 2006, 11:10 PM
UJ flange bolts 9/16" or 14mm - but it's a bit tight.
Wheel drive flange bolts 9/16" on RR, 17mm on Defenders
Good word 'Flange'
Si
mwncidur
May 28 2006, 10:26 AM
propshaft bolts 3/8unf
v8 crank pulley bolt 15/16 or 24
Oh yeah hello to all I'm new.
Mark
Jul 5 2006, 11:51 AM
Thought this was a useful reference so now pinned...
Mark
simonb
Jul 22 2006, 07:30 PM
300Tdi crank bolt 27mm (and its "fully" tight
Wading plug holes bell housing and timing belt case 1/4" BSP, same for series 3 bell housing.
300Tdi rad and thermostat housing plastic plugs 1/2" BSP ( for both of the above, brass and iron plugs available from plumbers merchants and larger B&Qs)
Jon White
Jul 31 2006, 11:02 PM
6 bolt pas box drop arm nut 36mm
diff pinion nut 1" af
freelander petrol k series cylinder head bolts E12
bush doctor
Dec 8 2006, 06:54 PM
QUOTE (dirtydiesel @ Apr 25 2006, 12:49 AM)
33mm fits Danny
western
Jan 20 2007, 03:53 PM
What vehicle ? IIRC the 110's rear Salisbury nut is bigger probably 32mm, but don't qoute me, as it was ages since I had to swap the oil seal in mine.
Phil Hancock
Jan 21 2007, 11:49 AM
Salisbury pinion nut is 32mm.
Salisbury crown wheel bolts 19mm a/f.
Salisbury differential case bolts 19mm a/f.
Salisbury bearing cap bolts 19mm a/f.
MikeRowen
Jan 24 2007, 10:39 PM
1991 110 Def: Nut on front of rear diff (Salisbury), behind/inside prop-shaft flange, is 32 mm.
3lions
Jan 26 2007, 06:27 PM
300 Tdi.
Sump plug : 19mm spanner / socket.
Rocker cover bolts : 13mm socket (ratchet spanner for the back one on Disco!)
Auxillary drive belt tensioner : 15mm socket / spanner.
Tappet adjuster locknut : 13mm.
Heater plugs : 10mm deep socket, 7mm socket / spanner for connecting cable.
Thermostat housing : 10mm socket.
Crankshaft pulley : 27mm socket.
Wheel nuts : 27mm socket.
Coastcard
Mar 20 2007, 08:57 AM
110 CSW with self levelling unit.
The A-frame ball joint nut is tucked away in the casting with very little clearance. After trying 3 different sockets, I found a Tengtools bi-hex 30mm socket fits. No reference number I'm afraid, but it is matt silver (not shiny chrome) and quite stocky!
Bull Bar Cowboy
Apr 10 2007, 02:44 PM
A couple of common ones,
V8 Crankshaft pulley bolt …. 15/16 A/F
V8 oil pump bolts ……….. 5/16 A/F Ring Spanner (12 point bolts)
Ian
BigSi110
Jun 7 2007, 08:44 AM
Defender, but I assume virtually any Series or 90 / 110 / 130
Transmission brake adjuster nut on drum = 17mm spanner or socket
tychoS
Jun 16 2007, 06:20 PM
2,5 n/a & 2,5 TD
diesel filter banjo bolt - 16 mm
injection pump bleed screew - 8 mm
90"/110"
swivel house filler 11 mm square
swivel house drain 10 mm square
land rover diffs filler 1/2" female
land rover diffs drain 1/2" female
LT77 filler 1/2" male
LT230 filler 1/2" female
DiscoStu
Jun 22 2007, 11:03 PM
Disco 300Tdi.
Rear suspension upper link bolts = 1 3/16" AF socket.
Upper link to ball joint = 19mm sockets both sides and can be vey tough to split.
Rear suspension trailing arm chassis mounts = 1 3/16" AF socket.
Rear suspension trailing arm to axle = 24mm socket.
300Tdi rear caliper bolts (12 sided) have an m12 thread and do not fit 200Tdi axles, they're too big. Need 1 size smaller but in Imperial, if that makes sense.
Stu.
DiscoStu
Jun 30 2007, 03:10 PM
Axle, gearbox and transfer box breathers (Banjo bolts) are 9/16 AF or a tight 14mm. These can be replaced with much better fittings from your local hydraulics/pneumatics store. Thread size is 1/8 BSP. I'd recommend elbow swivels.
alan kemp
Oct 3 2007, 05:26 PM
300 tdi belt tensioner 15mm
Type R winches - 3/4 Hydrolic hose nuts 27mm
Would be a good idea to add the torque setting for each. No idea what the above ones are.
Si, I like gusset just as much as flange.
David Sparkes
Nov 1 2007, 06:38 PM
From post 3 -- "2.5 NA crank pulley nut 41mm".
When this bolt incorporates the dog for the starting handle the size is 1+11/16"AF.
43 mm appears to be the nearest Metric size
Expect this socket to be 3/4" drive.
For the 38A Range Rover:
R380 5 Speed Gearbox
Drain plug 32mm + Copper Washer, 25mm ID x 32mm OD,
Fill plug 55 Torx (Tx)
Borg Warner Chain Transfer Box
Fill and Drain plug 13mm Female square
Axle differentials
Fill and Drain plugs 13mm Female Square
Glow Plugs
Glow tube plugs - one pole, 25x6mm
Voltage : 11
Thread : M12x1,25
Spanner width (AF) : 12 mm.
Diesel AC Compressor belt tensioner
13mm AF Spanner
10mm AF Allen key. Turn Clockwise.
Torx bit list
TX40 - Ball Joints on Drag link and Tie bar.
Also Front seat base to runners.
TX45 - Front Seat Runners to bodyshell.
TX55 - R380 5 Speed Gearbox Fill Plug.
Wheel Nuts 27mm 80 lbf-ft
Brakes
Caliper Pin Bolts, Front & Rear 12mm AF 22 lbf-ft
Front Caliper to hub bolts 19mm 12 point 122 lbf-ft
Rear Caliper to hub bolts 13mm 12 point 74 lbf-ft
Brake Disc to hub screws No4 Pozidrive. 18 lbf-ft
O Rings
Water pump
Water pump O ring 68mm x 6mmCS
Heater Core O rings.
22 mm ID by 2.5 mm thickness.
Use VITON if possible. Has better high temp resistance than the NBR-rubber (Nitrile?) used by LR.
EAS
Lines to/from the air dryer are 8mm,
to the air springs 6 mm,
and the venting line is 4 mm.
O-rings are those ID, and are 2.5 mm thick.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
