Help - Search - Members - Calendar
Full Version: Slightly OT but Tech as well
LR4x4 - The Land Rover Forum > The Lounge > International Forum
istruggle2gate11
Hi all,
I became the proud owner of one of Neil Whitfords fine creations (the Rock Rod ) a while back.
All in all its been fantastic, done a few mods to suit my pysique and some small repairs, had my first trial in it at the weekend where it absolutely wiped the floor (against Modified specials, LR and Suzuki's).
One minor niggle is the Cv boot retention, it has great steering lock and good articulation, but when using either tie wraps, steel wraps or jubilee clips the boots pop off the outer end (the jubilee clips screw hits the wishbone bolts and screws and then tears the boot).
So, does anybody know of a slimline but effective method of retaining CV boots (a strong tie wrap type of thing)?
Cheers
western
Freelander does have CV boots, EPC shows these 2 'circlips'
TDL100190 -- large diameter -- outer
TDL100240 -- small diameter -- inner
haven't got a clue if these will be any good, but would be worth a look at some at your nearest main stealers. rolleyes.gif
GBMUD
I had this problem with my Honda quad. One CV had lost it's gaiter circlip and, every time I went round a corner the gaiter would come off and stay off. I mended it with a cable tie and, you guessed it, it came off straight away. I replaced the cable tie with locking wire - the type you might use to hold your main bearing shells on or somesuch - once around, twisted tightly and it was just fine thereafter.
Chris
BogMonster
Disco 2 has CV boots on the front as well, open swivels rather than the more conventional leaks-like-a-sieve type biggrin.gif
MogLite
Mikalor clamps ?
@ Demon tweeks
My local hydraulic place sells zinc coated steel ones pretty cheap too.
jules
QUOTE (MogLite @ Jun 6 2006, 08:40 AM) *
Mikalor clamps ?
@ Demon tweeks
no too big Andy
the freelanders come with a slimline clip which is only a few mm
there for the shocks don't hit it a rip them off.
the tool that is needed is about £75 is I never got one but bearmach found one for me..
simonr
I'm wiht Chris on this one.
Bind it with either wire or string/twine. Either will be much stronger, lower profile and longer lasting than tie-wraps.
Si
Diff
I have often used wire on CV boots too. You don't need any fancy tools, just a pair of pliers. It is better to use a wire that isn't too thin or it could cut into the boot. I have often used the uninsulated copper wire stripped from some 'twin and earth' household ring main wire. Put a loop round the CV, cross the ends over, grab with a pair of pliers close to the CV pull and twist. With copper wire, you will only get a couple of twists before the wire snaps at the twist, so don't go mad. Put two loops on each CV in place of a normal CV clip.
If you are having problems with the boots pulling off the CVs due to tight cornering, degrease the lip of the CV and boot and fit in place with a smear of RTV sealant before doing the wire ties. Once cured, the RTV will act as a glue to help hold the boot on.
Regards,
Diff
jules
QUOTE (simonr @ Jun 6 2006, 08:50 AM) *
Si
Trust me I have done a few CV's on my two rally freelanders as they have eight of them on each car and GP their £520 a pair...... ohmy.gif
The clips that they come with are perfect if the gaters are not held solid the grease will come out and destroy the CV in a mater of a few miles. Which can be very expensive
I can't find a pic of them on the web....
Its the same as the clips used on water hoses but there one use.
istruggle2gate11
Thanks for the reponses...
QUOTE (jules @ Jun 6 2006, 09:27 AM) *
Jules is this the type of thing? Using these?
QUOTE
I have tried using a tool and wire that is used for closing sacks (potatoes etc) but the wire's were not long enough, I could give another try using a more suitable wire I suppose.
GBMUD
QUOTE (898kor @ Jun 6 2006, 10:40 AM) *
Chris
jules
Thats the kiddy
There cheap as well
najw
Roger
These were used originally
and if they are put on tight enough they don't come off.
Can't remember where I got them though - think they were ThermoTec but not shown on Demon Tweeks now!
Porny
We use Band-it's at work... with one of these on, the CV boot won't go anywhere.
Means you need a 'band-it' tool though, which aren't that cheap.
We use them for various pipework, although band-it's are what come as standard on some OE CV's.
http://www.band-it.co.uk/auto.htm
Ian
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
