Help - Search - Members - Calendar
Full Version: Helmets and harnesses or not?
LR4x4 - The Land Rover Forum > The Lounge > International Forum
Pages: 1, 2
northernchris
As it says who would or wouldn't wear helmets and harnesses.
The pros and cons.
Std seat belts hard to get on when on unlevel ground.
Harnesses slighty slower to use but can be put on when on side slopes etc.
Helmets,dampen noise ,hard to hear co driver BUT with any half decent open face helmet you can fit ear pieces for the radios.
If we where running to MSA regs you would need atleast 8" clearance around your head in case of it impacting with inner cage/bodywork and that IS when wearing a helmet.
Chris
Tangoman
Chris, I would have no problem wearing a helmet already have 4 point harneses.
northernchris
QUOTE (Tangoman @ Jun 13 2006, 08:38 PM) *
I think it is going to go that way,i dont see why people dont want to wear them,if they complain about the cost,well in the great scheme of things it is not alot of money compared to the cost of our challange trucks.
Chris
minivin
however strapping an extra kilo of weight to the top of your head is going to do no good to your neck and spine particularly in shock load situations, better to wear something like a tank drivers lid like the padded WW2 things that will at least stop you from head-butting the vehicle, yet won't strain your neck
LR90
I see cost as an issue making entry to the sport more difficult but can see the merits in adopting MSA regs. We seem to be seeing more rolls on events now as they get tougher and I'm personally less keen on competing in my 90 which doesn't have a cage whatever the regs might let me get away with. Harnesses are not expensive but difficult to live with on a DD but I wonder how many cages would pass MSA?
TJ101
QUOTE (northernchris @ Jun 13 2006, 09:46 PM) *
Chris
It will more that likley go that way,, following MSA regs, BUT where does it stop,, if it goes along the lines of stage rally regs, add in the cost of approved helmets (£400), seats,(£400) harness (£220), overalls, (£450) plumbed in fire fighters,(£250) etc, etc
Then that will be followed by FIA regs, ie, change the lot every 5 years (cost of aprox £2k+ etc)
Am sure none of us want to skimp on our own safety, but in this day and age, its only a matter of time, before we are told, the above has to be done !!
northernchris
QUOTE (TJ101 @ Jun 13 2006, 11:43 PM) *
Approved helmet £150 upwards, harness £90 upwards, seats £300 pr pr fire system club level £120
As for tank helmet what drugs are you smoking?????????????Sure they use them in WRC,F1 etc ohmy.gif ohmy.gif
MogLite
We are planning to use helmets in MogLite
el-cheapo motoX lids are the current favourite
The thinking behind this, is a cheap (I assume polycarb) will be light
It will protect against bumping your head on the cage in a crash, with a full cage, I think more would be overkill.
The ability to wire them for sound is important, also with no windscreen/doors we need some kind of goggles/face-protection from flying stones/mud/ramblers.
Sparco harneses are ready to go in
Seats are again el-cheapo Vauxhall seats, for comfort and cost. Also race seats provide useless rear visability for challenge style events.
The ability to tilt them forward for access to the space behind is important for me too.
I've tried to get the rest as safe as I can - albeit on a budget, fireproof bulkheads, electrical kill switches etc.
I would like a plumbed in extinguisher - I'm used to driving oil-burners - petrol is scary
TJ101
QUOTE (northernchris @ Jun 14 2006, 08:52 AM) *
Chris ?? tank helmet ??
my prices quoted were approximate, for decent gear,, NOT cheap crap stuff, having just refitted one of the hire cars to current FIA spec
obviously smoking better quality stuff that you are,
minivin
Having a friends daughter break her neck because the inertial weight of a helmet in a accident, I have first hand knowledge thank you mad.gif
Diff
I would consider wearing a helmet, regardless of what the regs are. Even a lightweight cycling helmet can prevent serious injury. Having had several rollovers in my trials buggys, I am very aware of how it is physically impossible to prevent your head from being thrown about by the motion of the roll. I had a serious roll once, and if I had not been wearing a helmet (open face m/cycle), I may have suffered a serious injury. The force with which my helmet hit the rollcage was enough to stun me momentarily.
A lot depends on vehicle design as to what, if anything your head is likely to come into contact with. In a Land Rover, the window/doorframe/post is the most likely providing you are well strapped in and you have a suitable high back seat and headrest.
I have had previous rollovers without a helmet where I have been fortunate not to have hit my head so hard.
My choice would be full harness and lightweight helmet.
The sport may not need to go to MSA regs so soon, if competitors wore helmets and harnesses.
The more injuries that occur as a result of roll overs, the more likely the sport will be pushed towards MSA regs.
I haven't competed in a winch challenge, but I used to regularly compete in AWDC class 1 modified trials for which there are specific MSA regs regarding vehicle design etc.
Regards,
Diff
dirtydiesel
To be fair the worst case with the msa is that you would have to prep yourself and your car to compsafari spec.
Ie:
Approved rollcage,
min. of 3 point harnesses,
helmet to the relavent british standard.
At the end of the day it is only going to be classed as a clubmans event, no need for full international event rules is there.
IMHO Most (if not all) of the injuries i've seen at off road events wouldn't have happened, if the level of vehicle prep was higher.
QUOTE (northernchris @ Jun 13 2006, 08:24 PM) *
Are you sure the above is correct. last time i looked it was 50mm above top of helmet, and 50mm to the outside of your shoulder.
LR90
The MSA approved cages, would these include exo cages or only internal and is a simple hoop and backstays sufficient?
Diff
QUOTE (LR90 @ Jun 14 2006, 12:30 PM) *
MSA rules adopted by the AWDC for 4x4 crosscountry vehicles are different to those for high speed events. IF MSA rules were to be applied to winch challenges, in my opinion, they are likely to be along the lines of the MSA regs adopted for modified trialling. These regs are sensible and for a roll cage would be for internal or external, two hoops, two straight backstays and a diagonal in the rear hoop or very close to it. Minimum material is blue band steam pipe. Dirtydiesel's dimensions regarding helmet clearance are correct for these MSA regs.
Regards,
Diff
dirtydiesel
I would like to see a minimum of drawing no. Q36 in the msa blue book.
But i bielieve the current min. for awdc speed events is drawing no. Q6a.
A simple rear hoop and stays is just not enough.
Les Brock
I'd like to see helmets and harnesses for the driver, not sure about the biatch though unsure.gif
1, It most cases...well in our case anyway I'm out of the vechicle watching/directing, where there is a possibility of a roll, ready to put my substatial weight on the light side laugh.gif
2, With all the activity required it might get slightly warm to say the least for the biatch
With punches becoming more challenging I think something is required
on to Scutineering......it's there for a reason and "flak hat" on....if it fails it fails, not a case of get it done for next time but you can compete blink.gif .....lots of things arn't and still the same next event mad.gif
OK most things, arn't safety related and no way would they pass if it was, but rules is rules !
ltwt1981
In many cases the reason for a fail is not a criticak safety issue, the normal route is, take it away and try to fix it, ask other competitors for help.
Comes back after best endeavours still not right, we would then say,
1. Safety criticakl, sorry fail.
2. Not critical, fix it for next time. Chief will then talk to eligibility scrutineer who will see this vehicle next time, if not fixed next time then don't get to play.
This works for us in racing, but in off road the eligibility scrutineer may not exist and the club scrutineers change.
The way forward is then a log book, maybe not in the currently accepted sense but must be signed at each event by scrutineer, any problems are noted and next time scrutineer sees it and checks.
Couldn't be fairer but competitors don't like log books.
Will they remember to bring the log book, we had a competitor at Brands Hatch the other week who actually forgot to bring his car with him.
Exmoor Beast
Its been suggested that this be moved to the Int' forum which seems sensible to me as not everyone uses this section.
So if thats alright folks....
D9OSV
Intresting thread Chris.....
Have had to wear helmets on several occasions abroad and in the UK whilist competing, and two major things have raised there head as a result...
After wearing a helmet for two days competing i actually find that i am NOT in pain from muslce aches etc...
I think this is because i am not trying to constantly stop my head hitting the the roof and vehicle side the whole time, thus not stressing my neck and shoulder muslces as frequently....
The other thing that raised it's head is that, give someone a helmet, gloves and a car and all of a sudden they think there Nigel Mansell !!!! huh.gif
Seen it plenty.......
This sport is changing, I have been doing this along time and it is getting very competitve.....
Bad thing???? Who knows??
But i think you'll have difficulty getting some to wear helmets in the UK, They will feel they are having to suffer to others inability to judge terrian.........Or .........Drive ph34r.gif
Some events state that you must wear a helmet etc, but not what type or whether or not it's approved.
I think this is a sensible approach as any helmet is better than no helmet, but i also understand that this in itself will cause problems in this litagation strewn land rolleyes.gif
As for the recent roll overs etc.... Very sad and i hope all our well, but we have brought it upon ourselves by having one day competitive events..........At two days events most are not so heavy footed because the vehicle MUST last two whole days..........Nuff said tongue.gif
The poor competitors that unfortautely rolled must also take some blame for getting it and their judgement wrong, I strongly hope this acts as as reallity check for everyone tongue.gif
I also strongly believe that a little of what started the challenge scene has been lost ie: The Challenge, Team spirit and the will to help others.
Anyway.....Where was i ?????
D9OSV
One thing i forgot to add is that as a driver YOU do not HAVE to do ANYTHING you feel is dangerous......
Or is that the problem? People are scared to say NO!!!!!
jules
I race so have no issue with wearing a helmet
Having said that I would not wear me £350 Peltor helmet for challenging I would go for a cheaper one but would fit a radio intercom or Blue tooth to it.
I have in the past got MSA approved helmets for as little a £50 when I was first racing....
The cage is no issue either as my cages are always built to MAS/ARC guide lines anyway for my own safety....
Extinguishers £25 for a AFFF so that's no hard ship as I carry them in the challenge truck anyway....
Plumed in is not a requirement in comp safari I do have them as a last resort in the racers but not the challenge truck and I have no planes to fit them.
Harnesses all my competitive trucks have them again I prefer them over normal ones as you never know when you could get it all wrong..
I can't see the FIA getting too involved at this stage and its not racing...
GBMUD
What about reducing the number of roll-overs rather than just making it safer? Take away all of a competitors points if he rolls his truck - which will give him some incentive to be careful. Or take a £500 deposit and keep if he rolls. smile.gif
Chris
tombraider110
Both my kids wear the bike hats when they are off road on play days and that is there choice to. my 6 year old can fall asleep in the back of the 110 when her dad is have great fun. So i wont complane if i have to as well
jules
QUOTE (GBMUD @ Jun 14 2006, 02:36 PM) *
Chris
We don't roll the trucks deliberately
northernchris
QUOTE (TJ101 @ Jun 14 2006, 09:15 AM) *
HOW CAN IT BE CHEAP CRAP STUFF IF IT IS APPROVED BY THE MSA?????????????????
northernchris
QUOTE (minivin @ Jun 14 2006, 09:29 AM) *
Mini that must have been a freak incident there are always going to be situations where a helmet doesnt help.
northernchris
QUOTE (dirtydiesel @ Jun 14 2006, 12:19 PM) *
Ie:
Approved rollcage,
Just check the blue book i am dead sure it is more than 2 " .
GBMUD
QUOTE (jules @ Jun 14 2006, 04:09 PM) *
I appreciate that... but you would think a whole lot harder about what you were doing if you knew it was going to cost you all your points - I do not know what would constitute rolled mind you. Mo has a picture of my 90 with two wheels off the ground on one side while leaning against a bank. Were it not for the bank I would have been right over - Sandbag, in the passenger seat, was not impressed! Just a thought.
Chris
D9OSV
QUOTE (GBMUD @ Jun 14 2006, 07:44 PM) *
Chris
Brian Hartley (Club offroad Aka Bulldog, etc....) has been Taking points of teams for roll overs for somer time now......
Who in there right mind would roll a car on purpose? For what gain?
Just to smash your car up???????
It ALWAYS leads to arguments of "Is it a roll over, No it's got two wheels on the ground"
Or "i can't have rolled i was in a ditch"
I was nearly penalised for a roll over at last years bulldog, but as we ALL pointed out, I drove in and drove out without the assitance of a winch.........
Whether or not i had only two wheels on the ground is inmaterial, I WAS IN CONTROL.....(ish tongue.gif )
So was that a roll over????
I rest my case.......
Added to this the fact i was AGAIN accused of a roll over the previous years on the night section!!!!!!!!!
Turned out the marshall saw a jeep that was a similair colour to the SV roll and blamed me blink.gif huh.gif
Soon put him straight laugh.gif laugh.gif (Lots and lots of friends and witness's cool.gif )
People just need to get off the throttle, and accept that accidents happen.
I HATE speed restrictions at events as i personally believe that they, again, cause more problems than they solve.......BUT, if this is what takes, then so be it.....
I think we need to look back at events of old and how they got round the problem of noive or inexperienced drivers biting of more than they could chew.......
They used to have prologues, where the skill of the vehicle team was tested and then the start order was arranged from this....
This usaully meant that the top teams got a way from the inexperienced leaving the lower teams to do things at there pace..........
I don't want to be wrapped in cotton wool and told to drive only on the dry bits!
So less rules and less punches,
There getting boring and very difficult to marshal, thus leading to accidents as we have seen........
More super sections........with punches, equals more control and less incidents......
Ps: Helmets are great ph34r.gif
dirtydiesel
QUOTE (northernchris @ Jun 14 2006, 06:44 PM) *
Sorry mate your wrong, blue book says;
top of cage min. of 50mm above top of helmet,
Side of cage min. of 200mm from center line of body
Section Q(safety criteria) drawing No. Q31.
dirtydiesel
Well said that man!(jim that is)
I've got a msa approved helmet (with this years sticker on it no less) that only cost me £45.
What a s**t idea, it wouldn't stop people from rolling. just penalise people that are having a bad enough day.
I personally would like to see an event comprised soley of special stages, each one having a DNF time, but to add a little more thought into it there should 5 or so punches on each stage that are worth negative time.
eg. you complete the section in 22mins and in that time you've also collected 2 punches each worth -5 mins
a time of 12 mins is then entered on your score sheet.
The team with the lowest time wins.
This would be a lot easier to marshal !
But then again the organisers would only go an ban portals.
minivin
QUOTE (northernchris @ Jun 14 2006, 06:42 PM) *
Unfortunately it's not, I know a few people who have suffered neck injuries due to crash helmets, ranging from the serious of death to riplash, the neck isn't designed for a kilo to two kilo's being strapped to your head. This is why night pilots with Night Vision Google's are required to remove their NVG, store them securely, and then eject from an aircraft, as they snap their neck or at best very severe riplash during ejection otherwise sad.gif
northernchris
Dirty
Is that not for saloon cars mate?
Anyway wouldnt it make more sense then?
northernchris
QUOTE (minivin @ Jun 15 2006, 08:18 AM) *
Mini
I am not talking about high "G" loads here i thought we were on a landrover forum!!! Lets just agree to disagree.
minivin
QUOTE (northernchris @ Jun 15 2006, 08:25 AM) *
Mini
dirtydiesel
QUOTE (northernchris @ Jun 15 2006, 08:21 AM) *
Dirty
There's nothing that superseeds it in section H,
I wouldn't get too worried, it is a minimum requirement, nothing to stop you making the cage bigger.
jules
How small must your cab be for a helmet not to fit inside the cage.
(hang on I'm only 5'9") now I can see why there would be a issue
I race with helmet at first yes they can be a pain but your neck will adapt so much so that's I got rear ended by a omega on the M3 and got concusion but no whiplash work that out casualty had issues with it also.
Trouble is I find you can feel indestructible with a cage and harness and Helmet on which could lead to more rolls etc.
But Jim and Northenchris I am in agreement with full.
(but I have not competed in the top level challenges yet but have in the top level comp safari)
The cost of preparing for new helmets and harnesses is going to be minimal only £350 for two helmets and a two sets of harnesses.
Does anyone know if 2" harnesses have been band yet for 3" ones..
The Fire suit thing.....
The BORC overall British champion races in old overalls
I only wear cheep karting ones for ease there is absolutely no reason for anyone to worry about that being imposed..
ltwt1981
MSA Harnesses for racing must be FIA approved and in date as of Jan this year.
This has banned 2" for racing.
I suspect overalls will soon be timed out, i. e. ten year life.
freeagent
you can always wear a neck-brace below your helmet, although they do restict head movement when you could do with out being restricted....
ltwt1981
Go the whole hog, get a HANS device.
It will restrict your movement though and you should use the proper harnesses.
jules
QUOTE (ltwt1981 @ Jun 15 2006, 02:43 PM) *
I tested a copy of that thing in race condition
Its comfortable as when in a straight line but going round a corner forget it..... ohmy.gif
and getting in and out is a nightmare..
My mate was marketing them and said its well cheep its only £400 where as the Hans it is about £1700 ish
ltwt1981
As you say great for racing and works in high speed crashes, but not too good for a challenge event winch bitch.
Could be fun to watch though and will reduce the number of punches done.
The winch bitch could get round it though by not riding in the vehicle and running everywhere with it, could produce some Olympic athletes that way.
jules
QUOTE (ltwt1981 @ Jun 15 2006, 03:06 PM) *
MM
My bitch could do with the exercise.... (good job the wife's not on the forum)
my other winch bitch is too short I would end up runing him over laugh.gif laugh.gif
Fatboy
QUOTE (jules @ Jun 15 2006, 03:15 PM) *
Come on Jules ! You could make life significantly safer for him then - Get him to wear a helmet to protect his head and stick a flag on the helmet to make him more visible tongue.gif
northernchris
So what is the general concensus??? YES or NO to wearing helmets.
D9OSV
YES, YES ,YES
YES, YES, YES
AND
YES!
MogLite
QUOTE (D9OSV @ Jun 15 2006, 05:45 PM) *
YES, YES ,YES
YES, YES, YES
AND
YES!
Yeah - what he said
dirtydiesel
As above.
jules
I'm easy happy to be safe there is no cost on your life..
but it need to be all or nothing
(all wear hats or none)
ltwt1981
If buying a helmet it is prudent to check it is Ok and to MSA regs Snell 2000 or better or SFI 31.1 31.2. or relevant BS.
We get a lot of motorcycle helmets sold as suitable for racing but not to Blue Book standard.
Check the Blue Book before buying, you won't get past scrutineering if its not right.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
