Help - Search - Members - Calendar
Full Version: Part Number / Manufactuer Number Needed
LR4x4 - The Land Rover Forum > The Lounge > International Forum
Hybrid_From_Hell
Righty ho
Been doing some research and chats with a mate
Can anyone please tell me the Plug make model number / part number etc for
A Disco 2 V8 say a "53" plate ??
Nige
western
From EPC
RC11PYPB4 - Double Platinum for V8 D2 4.0ltr efi, LR part NLP100320 i-m_so_happy.gif
Hybrid_From_Hell
Can anyone now move this to a Bosch NGK Champion etc plug pert number ? unsure.gif
Come on now
Nige
BogMonster
QUOTE (Hybrid_From_Hell @ Jun 24 2006, 05:18 PM) *
Come on now
Nige
Nige,
That is what mine has and I am almost sure they are a different physical size so will rattle a bit in your spark plug holes. Will try and find one of my old ones tomorrow and check it against a "normal" one smile.gif I know for sure the spanner is a lot smaller and I think the plug thread is too but wouldn't swear by that.
The RC11thingy is a Champion plug number by the way, and IIRC they are the wrong side of 50 quid for a set blink.gif this platinum stuff they are coated with doesn't come cheap ph34r.gif
On the plus side it starts immediately every time and runs like a sewing machine so I can vouch for the positive side of running non dizzy ignition smile.gif
Hybrid_From_Hell
Steve,
Ta
May well be the body of the plug is the skinny type with smaller "Spanner Size" but same thread and end for the cyl head. Need to do some research yet, but please do have a peek
BogMonster
OK here you go, on the left is a standard 3.9 plug Champion RN11YCC and on the right is the Champion RC11PYPB4 that fits my 4.0 (which has the "Thor" engine/Bosch engine management/four coil dizzyless ignition system)
Everything else is smaller except the thread and reach which is identical so the good news is that they will physically fit smile.gif
According to the "spark plug bible" at work, the rest of the plug number is:
R - resistor
C - the physical dimensions 16mm head instead of 21mm; reach is 19mm and thread is 14mm same as the RN ones
11 - heat range
PYPB - Platinum tipped electrodes with insulator projecting 1.5mm and tapered off ground electrode (same projection as the YCC except platinum)
4 - plug gap 1mm which I make 39 thou in the old money
It says somewhere else that you mustn't adjust the plug gaps on these as jamming a feeler gauge in there will damage the platinum coating, and since that bit is what presumably costs £7 odd I guess you wouldn't want to do that blink.gif
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
