QUOTE (Hybrid_From_Hell @ Jul 6 2006, 10:02 PM)
Much will depend on the style of the cage, have you any ideas in mind ?
There is a wealth of experience here that can help you...........some even good
Seriously can you give more idea as to what you are after ?
Nige
What im looking at is the Standard ARC welded external cage. Whitbread have a few up for grabs. Front Hoop and rear are already fabbed. Just a case of roof bars and rear extended mounts to weld on. So it has 6 mounting positions on the chassis. I just want to get an idea of the best way to prep the mount positions on the chassis.
This design, but no front wing section. Just the truck cab area and two rear tub tubes.
Cheers
