ROGUE TROOPER
Jul 12 2006, 12:07 PM
Im currently building a TT of my own design using T25 turbos and a fabricated exhaust manifold as the Janspeed Twin turbo design was not built for EFi (turbo too close to the plenum)
I thought of using 3.9 V8 "twin" cast manifolds (4>2) then take manifold forward and up to meet the Turbo(s) in front of the front cover.
Do you think this will be ok?
I know that the studs wont support the Turbos on there own so a bracket wil be needed.
Just to let you know of the plans so far............
3.9 V8 (if I find a bigger CC one I will use that)
Buick 300 heads (cast steel, big valves!!)
2 x garrett T25 Turbo chargers with waste gates
Twin "apposing" plenum (inlet each side)
2 x Intercoolers (300TDi so far!)
Meggasquirt
EDS (using Montego coils)
Electric water pump
Jon White
Jul 12 2006, 12:17 PM
Have you considered the DIY kit form tubular manifolds? You basically get the flanges that bolt onto the engine, and then a load of tubing and bends to cut to whatever length/shape you want and then weld it all up so it can pretty much go wherever you want it to!
Jon
02GF74
Jul 12 2006, 01:26 PM
have you given any thought how you will stop this 1,000+ bhp 2 ton behmoth
(or have a large supply of fresh underwear
dollythelw
Jul 12 2006, 01:33 PM
how much boost are you planning?
SHAVED_GORILLA
Jul 12 2006, 08:43 PM
Have a look at TVR 4.0l Griffith manifolds the face forwards to meet at the front collector box.
SG
Steve Hiatt
Jul 12 2006, 08:47 PM
Just fit a Chevy
ROGUE TROOPER
Jul 12 2006, 09:28 PM
QUOTE (dollythelw @ Jul 12 2006, 02:33 PM)
5-7psi max
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
