Help - Search - Members - Calendar
Full Version: what exactly stops the diesel engine..
LR4x4 - The Land Rover Forum > The Lounge > International Forum
pigster
I always thought that the stop solinoid shut off, which then put the plug into the whole and hey presto motor stopped.. however read that someone is running a diesel with out the solinoid in place - how does it stop.
Does it cut something esle as well... ? is it the solinoid that does the business? its a 200tdi by the way.
thanks in advance.
will_warne
QUOTE (pigster @ Jul 27 2006, 09:38 AM) *
thanks in advance.
Manual fuel shut off?????
white90
the solenoid shuts the fuel flow when power disconnected as it holds the solenoid in the open position
without it a manual shut off as Will says or stall the engine no other way that is practical
of course:
running out of fuel
removing FIP
Lara
Best way I ever heard of is to drive into deep water with about 6000 rpm showing ohmy.gif ohmy.gif
Lara.
dollythelw
I prefer trees Lara - restarts not so much of a problem, cheap firewood although bodywork bill rise a little bit
Les Henson
If the fuel solenoid has had the plunger removed, then the engine will start still, and will make the vehicle slightly easier to steal. However, switching off the ignition won't stop the engine, maybe a decompression lever to stop it, although fitting one would be engineering work. Stalling the engine would be the easiest way, although not so good for the clutch I would have thought. Blocking the inlet manifold with some kind of flap valve - similar for the exhaust.
Or BishBosh, who won't stop it immediately, but he'll get it stuck for so long it'll run out of fuel and conk out anyway tongue.gif
Or White90, who'll not actually ever get to start it, as he'll be constantly taking it apart to fix/modify bits of it. laugh.gif
Disco Dunc will bash it with a hammer, swear at it, and then cut it up with an angle grinder tongue.gif
HFH will make it so heavy, it'll just plain refuse to start in the first place!
Turbocharger will make so many intelligent, incomprehensible remarks that the engine will get an inferiority complex and stop anyway.
pigster
hahahaha...
thanks for that...
so in a nut shell... it needs it to turn off.. right ok..
some methods are a little extreme I reckon .. but one day I may just give them a go.. biggrin.gif
white90
nice one Les
I have a corner of a field reserved just for you
deleted
QUOTE (Les Henson @ Jul 27 2006, 10:30 AM) *
We used to have a Kubota compact tractor, and that had a decomp lever to aid cold starting. in the "Japanese translated manual" that you got with it, it stated "that the decomp lever should never be operated when engine is running as valves might bite dust" rolleyes.gif biggrin.gif biggrin.gif biggrin.gif (cue Queen song: "another one bites the dust...")
QUOTE
A mate of mine working on his diesel hi-lux tried this by using a rag directly onto the end of the inlet manifold (as he had his air filter disconnected).
it took him ages to remove the head, then remove the bits of rag.... laugh.gif laugh.gif laugh.gif
Les Henson
QUOTE
just mind the stingers
deleted
QUOTE (Les Henson @ Jul 27 2006, 11:42 AM) *
Reminiscent of "Delivarance".....
"Squeel like a pig booooy...."
Bush65
My 4BD1-T engine has a manual stop lever on the injection pump.
I was in a yacht race to Lord Howe Island one time, with very bad weather and big seas.
With the mainsail fully reefed and a storm jib, we were still overpowered and the boat was sailing on her ear.
The Volvo auxiliary diesel was started to charge the battery (needed for navigation lights, instruments and communications). But could not be shut down as it continued to run on engine oil from the crankcase and the govenor in the fuel pump could not prevent it overspeeding.
Eventually the flywheel came off and stalled the engine.
callum
QUOTE (Bush65 @ Jul 28 2006, 02:29 PM) *
could they not just have cut off its air supply
i remember in one of the scrapheap challenges that after some enthusiastic tuning of a truck diesel engine it started revving towards destruction. most of the team downed tools and ran for it apart from one brave soul who suffocated the engine with, i think, a towel.
my isuzu diesel is a bit reluctant to stop when its really low, as in 5l or less in the tank, on fuel. on the few occasions it has happened i just stalled it.
Gnomeranger
Some older engines have a lever on the side of the fuel pump which basically moves the rack in the pump and the engine just stalls.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
