Help - Search - Members - Calendar
Full Version: Help...where's it all go?
LR4x4 - The Land Rover Forum > The Lounge > International Forum
2drdan
Evening to all,
has any one got any photos of the disco 200Tdi engine, complete with everything plugged or plumbed in..? I'm getting toards the end of the install in to the RR and it's a PITA trying to work it out from the manual and I haven't had one of these engines before! blink.gif
oh and whilst you there, theres a smallish threaded hole on the bottom of the front of the engine about level with the top of the sump....... what's that for then..? drain plug ?
Any help gratefully received,
Cheers,
western
find Les H's thread in the tech archive ref fitting a disco 200tdi in a 90, that hole is for your timing case wading plug, it will also let any oil leakage out from the timing case/crankshaft seal & camshaft seals. the clutch housing should have one too. fit the plug before driving in deep water it'll keep the timing belt dry & safe -- same for the clutch.
if you need plugs LR part is ERC7295 or visit your local plumbers merchants they can supply a identical plug.
2drdan
QUOTE (western @ Aug 15 2006, 07:11 PM) *
Brilliant, as always a friendly and helpful reply from this forum!
Thanks Western.
Hopefully when this is all finished I'll be able to get out there and meet some of the forumeers....!?
Phil.
western
although my 200Tdi is a Defender version most if not all the electrical connections are the same as for your engine, if you need any pictures to confirm parts location just shout.
2drdan
QUOTE (western @ Aug 15 2006, 07:25 PM) *
Righto cheers, will prob (not holding breath) be ok on electrickery as I have a tame auto sparky for a mate but we'll seee how it goes......... blink.gif
Gromit
I've an original 200 in a 110. Don't have a camera tho, but shout any specific questions and I should be able to answer, if Ralph and his seemingly web-enabled-forum-connected-wrist-watch doesn't beat me to it. biggrin.gif
western
QUOTE (Gromit @ Aug 15 2006, 11:02 PM) *
bishbosh
I have jsut put a 200TDi in my Rangie from a Disco.
What do you want to see and I'll take picies tonight....
2drdan
QUOTE (bishbosh @ Aug 16 2006, 08:55 AM) *
AH ha, great , if you'd be so good,
The piping for the intercooler from engine/from airbox/to turbo etc.
The rad pipes, I've got the bottom pipe with a smaller dia pipe coming off it.....can't see where that goes...
thats about it but a photo of the whole lot would be great, esp to see it in the RR engine bay for comparison......?
western
QUOTE
to the bottom connection on the header tank if it's the black or translucent plastic one, or if the metal oval one to the connection on that.
Andy
this pic is a few years old, must be its clean & white outside. any help?
2drdan
QUOTE (Andy @ Aug 16 2006, 08:08 PM) *
JST
i did the conversion article at the back of Les thread with DSN, drop either a line if you have specifics, although i expect Bish is best placed to advise having just done the job and into a rangie to.
2drdan
QUOTE (JST @ Aug 16 2006, 09:11 PM) *
Cheers, if I get stuck I'll shout !
bishbosh
Right, here you go. A bit grainy as it is pi$$ing it down and pretty dark, but you should see enough:
2drdan
great effort, I appreciate that, cheers, thats mucho helpo (sorry been to italy for hols...) with a bit of luck and some decent effort over the weekend it should be on the road by Monday....!!?? cool.gif
Andy
not tweaked it then bish? im sure i saw the emissions control caps still in place there. is it a 200 or a 300? i cant decide. its a 300 cover but i thought they all had serpentine belts?
bishbosh
It's a 200 and it was badly tweeked when I got it - emissions off the scale.
I am running in "standard" guise at the moment - economy is the name of the game!
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
