Help - Search - Members - Calendar
Full Version: Diff pinion oil seal
LR4x4 - The Land Rover Forum > The Lounge > International Forum
Mo Murphy
Are there two different types ? The new ones I have here (frc 4586) have a raised lip which foul the muck thrower.
Mo
western
that one frc4586 is for axles To (A)22S 08283B
the other is frc8220 for axles From (A)22S 08284B
Mo Murphy
Cheers Ralph, the other one (frc 8220) has no raised lip showing on the visible face I take it ?
Mo
BogMonster
Mo, you can buy a "flange kit" to change the older type to a new type with "new improved" mud deflector thingy, the flange kit is basically the new type flange and the new type seal so you change both together.
Not sure if the part numbers for the upgrade kit appear in the parts manual - I have a feeling they don't - but may be able to find them at work if Ralph doesn't find them in the meantime wink.gif
Mo Murphy
Thanks for that Stephen.
Mo
simonb
Thought they were interchangeable and the one with the deflector needs to be inserted so that its 4mm deep down the bore - like the other thread on the hub oil seals. IIRC there is enough space in the nose of the diff to put the seal in deeper.
Replaced the diff seal on my series 3 a few months back and think the seal for that was of a similar design, and i didn't swap flanges. Think its marked on the edge of the seal like the hub ones.
JST
Mo - you dont seem to be having much luck lately with the motor, not all probs from BDB06 i hope......
Mo Murphy
Just doing jobs whilst the diff is out James, routine maint if you like.
Diff is back in now and hubs back on, just the front output seal and and diff input seal to do in the morning and the landy will be mobile again smile.gif
Then I'll take the other diff with the locker in it apart, and find out how much it's going to cost sad.gif
Regards
Mo
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
