Help - Search - Members - Calendar
Full Version: Another oil seal question
LR4x4 - The Land Rover Forum > The Lounge > International Forum
Mo Murphy
I have two apparently different hub seals here, ftc 4785 and rtc 3511. Is one an old and superseded part or are they for different years. I do recall talk of different seals, is one better than the other ? Which should I use on my 90 ?
Mo
Mark90
3511 is the older type seal that is reputed to be better than 4785. They are interchangable.
Gromit
Just using this as an excuse to play with image shack.
Sorry they're a tad big
Mo Murphy
Mo
simonb
Having just fitted a '4785.. It efectively a triple seal with a further dust shield. There is a double inner set of lips nearest the bearing, an outer single seal and then the 4th bit is nearest the backplate, this is more a "deflector" to keep the grud away from the other lips. This seal is to be fitted with the main body of the seal 4mm lower than the top edge of the hub bore - its marked as such on the edge of the seal. If you pop one over the bare stub axle you will see the function of the outer most dust shield bit.
simonb
Look at Les' excellent write up on rebuilding a swivel. '4785 type seal is in the dismantled hub showing it resessed by 4mm and the outer "deflector" seal.
Mo Murphy
Thanks Simon, I've put the 3511s in now, but I'll bear that in mind for future fits.
cheers
Mo
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
