Is their any reason to have manual stepper control?
Thinking like this:
Engine is setup to run the following items:
PTO winch that runs best at 1200rpm
Engine driven Endless Air with auto control
Very very low gearing meaning crawling at idle is an option
Hydraulical steering (or hydraulically assisted PAS box)
So you are pootling along in low first- get a bit stuck and want to winch out. Flick the manual stepper control and it raises the rpm to 1200 or so so that you have enough power to run all the engine driven stuff without any problems.
This would mean that you could crawl along without stalling- something that i find pretty dangerous at times. How would having the stepper motor on affect engine performance considering that i will be using a MAP sensor in the Megasquirt unit- therefore the stepper unit will only raise engine speed yes?
How would you actually control the stepper motot? do you supply either 12v or no volts and therefore it is totally open or totally closed- is this right?
