However, no smiles here at the moment………
Having just replaced the valley gasket due to the gasket to rubber end-seals RTV letting go and dumping a litre of oil over the engine front cover in 600miles ………. firing up the engine after the repairs, I noted a ‘chuffing’ noise, and on the V8 that is typical of a leaking exhaust manifold gasket …….. so I didn’t pay a great deal of attention to it.
Next day was a trip up the the M’way to Brizzle ……… on the way I noted the water temp was about 5/10 degrees above normal (as was the oil Temp) and the truck felt to be lacking a bit in the power department, but the journey was uneventful.
The journey back was a different story ………. Intermittent misfire started and by the time I got to M5/J24 one bank of cylinders had handed in the towel ……. and it seemed to be really struggling on the remaining 4 (you will see why later…. read on). As I couldn’t detect the misfire on the REV counter then the lack of one bank had to be fuel ……… it occurred to me that I may have knocked the resistor pack wiring when fixing the valley gasket …… any fault here on the input will cause this problem as the injectors fire in 2 banks of 4. After 10mins on the hard shoulder trying not to get killed
Saturday morning was spent with the diagnostics hat on ………. ‘chuffing’ appeared to be coming from ‘engine central’ rather than the manifolds ………. removing the oil filler and breathers revealed a good impression of puffing billy …….. but this was exhaust gas and not steam.
A compression check told me all I needed to know ………
Right Bank,
2 = 180+
4 = 180+
6 = 180
8 = 180+
Left Bank
1 = 180
3 = 180+
5 = 90
7 = 145
So, it looks like 5 has blown into the valley and also into 7 …….. that would explain why the valley gasket gave up …………. Head will come off tonight and I am hoping its nothing anymore serious than the gasket ……… the only other option is a holed piston ........... but that is usually accompanied with clouds smoke from burning oil.
I am really beginning to think Diesel is the way forward……… I keep records (yes, I know, its sad)……… and the history is not good,
Looking at it since the ‘attention to detail’ rebuild,
15K = both Tin head gaskets changed to composites due to the coolant smelling like an exhaust pipe.
32K = Right hand bank head gasket replaced due to blow between 4 & 6 …….. caused by a head centre row bolt letting go on the ali block threads
42K = this is where we are now ………. Another bloody head gasket ……. Left hand bank this time.
Other stuff,
8K = valley gasket ……… coolant leak
23K = Valley Gasket ……. Coolant & oil leak
42K = Valley Gasket ………. Oil leak
I am slowly beginning to lose my patience (I suppose I am becoming an old git now) with the V8……… it was probably good as a Buick until they let loose the Rover and Lucas crowd on it.
I’ll keep you guys posted when I lift the head tonight ……………..
Ian
