Help - Search - Members - Calendar
Full Version: What size tyres do I want?
LR4x4 - The Land Rover Forum > The Lounge > International Forum
GBMUD
1991 Defender 90 Tdi. 1.41:1 transfer. 3.54:1 diffs. 2" lift kit
I have BFG 255/85 16 MTs fitted to white 8-spokes at the moment and they are getting to the point of being past their best off-road - although legally speaking and based on milage covered so far, they probably have another 30k odd miles left on them rubberwise. A new BFG 255/85 16 comes in at a little over 33" I understand.
I was looking at the Greenway Macho tyres that Bish is running on his Rangie at the weekend and considering the difference in price between them and BFG MTs. The drawback seems to be in the size that they are available.
Things to consider:
  • I have had enough of the BFGs getting mud caught between the tyre and the bead EVERY time I drive in muddy/rutted conditions. Even at the 32PSI that I run them on road it still happens - not on the road you understand! smile.gif
  • I seem to be doing more and more road miles vs. off road miles.
  • I prefer greenlane driving to "mud-plugging" most of the time.
  • I seem to tow quite a lot, although seldom VERY heavy trailers, the caravan at a little over a tonne is about the limit on a regular basis.
  • I am not keen to change the wheels around for a second set - EVER!
So what I am saying is that I would like a tyre which
  • Offers good grip on the road
  • Is quiet on the motorway
  • Has good life on the road
  • Works well off-road - basicaly must be a mud type tyre.
  • Is more than 33" but less than 34" diameter
  • Meets this diameter requirement without being wider than a 10.50", ideally narrower. I just do not like wide tyres.
  • Inexpensive
  • Is resistant to getting mud caught between the tyre and the bead - unlike the bloody BFGs!
  • So, everything my BFGs are but without the mud ingress issue...
Have I just excluded every tyre other than BFG MTs and bead lockers? Is there any other, inexpensive, single application bead sealing system that WILL work? I am very happy with my MTs in all respects other than the mud/bead issue. I am not concerned with the numbers on the side of the tyre - other than it be 'E' marked. It is the actual, factual dimentions I am interested in.
Cheers
Chris
dollythelw
39.5 x 18 Boggers!
it just so happens....
Jon White
Why not just put tubes in them???
I've always run tubes off road for this very reason!
Jon
GBMUD
QUOTE (Jon White @ Sep 12 2006, 02:30 PM) *
Jon
I have thought about this. I am slightly unhappy about the idea for a couple of reasons:
The tyre is designed to run tubeless and the inside is supposedly not smooth enough for tubes resulting in random phantom punctures due to the tube being abraided by the inside of the tyre.
I worry about mud and foreign bodies getting forced through the tyre bead (as they do now) and puncturing the tube - although I am not certain anything would get that far in if pressure were maintained...
I do have a couple of tubes in the garage I could try. It should be easy enough to remove them again if they do play up...
Chris
bishbosh
If you're doing lots of road miles then a remould wont last you long. Then again they are cheap, which is always a consideration when you slice a sidewall after 500 miles.... mad.gif
A more agressive tread (like the macho) combined with your driving style may not be a good on road combination either... ph34r.gif huh.gif
Paul Humphreys
The Macho comes in 285/75 R16 I think thats abou the size you want. Its 6mm smaller than you have now, but a little wider. Its rated to 94 Mph.
Paul
Turbocharger
Kumho MT? Cooper Discoverer STT? Sounds remarkably like my question
SteveG
No idea on an alternative tyre, as I've looked a couple of times now and both times ended up buying 255/85 16's MT's smile.gif
I know what you mean about the bead and slow punctures, so do your neighbours after I was using the compressor out in the street at 7am that morning! tongue.gif It was when when we had the high temps too, so they all had their windows opened rolleyes.gif
The only thing to suggest there other tyre bead is northernchris's suggestion of using that glue to seal the bead. I'll have to get around to trying it some day.
Cheers
Steve
SteveG
QUOTE (Turbocharger @ Sep 12 2006, 03:12 PM) *
Kumho - too small or too wide
STT - only one size and it's too small
but apart from that good suggestion wink.gif wink.gif wink.gif wink.gif wink.gif wink.gif wink.gif
will_warne
Chris, IIRC Coopers still do a 255x85 r 16 in a 'mud' pattern. I had a close look at a 285x75 the other day and thought they looked quite good. Price wise I think they're also a couple of ££££ cheaper than BFGs too. Performance wise I'm not sure. I know of someone who's running them on a Land Cruiser as a daily driver and I could ask him if you'd like.
GBMUD
Ah! I searched for "tyres" before I posted but not for "tyre". D'OH!"
Chris
Kev Baldwin
Cooper don't do the Mud pattern STT in a 255, however they definitely do offer the ST, an excellent halfway house option between an AT and a MT, in a 255/85x16. This sounds better suited to your needs.
Only trouble is, according to Coopers importers at Sinton tyres, I've just bought the last four 255 ST's they had in the country...!
Sorry!
Bull Bar Cowboy
Chris,
I was very happy with my first set of Bronco Grizzlys ( they did about 21K) ………. However, the second set started to break up just as they were on their last legs (about 23K) ……. In view of this I decided that I would not go in that direction. I think the final straw was a rubber block coming off on the A303 and hitting the windscreen of a jam sandwich behind me rolleyes.gif ………… I boll@cked him for being too close biggrin.gif
After a lot of debate I am now using Super Swamper LTB in 34x10.50x16
http://www.intercotire.com/site36.php
they are available in the UK from LA supertrux …
http://www.supertrux.com/acatalog/Super_Swamper_LTB.html
The on road performance is OK ………… very comparable to the Bronco’s, but a lot, lot quieter. As they are cross plys , you get the ‘bogger hop’ flat spot when they have been stood for a while biggrin.gif ……… but it disappears within 3 to 5 miles and is not at all aggressive ……… in fact its hardly noticeable.
The general tyre quality is first class ……… and the walls seem super tough (so they should be for an 8 ply). If you look a the specs you will see they are designed as a high load tyre ………. therefore my road pressures are 15 front and 18 rear.
I have used them in anger and the off road performance has been good so far ……. Very, very good on wet grass sideslopes, OK in mud (but we need more rain), OK on rock, and they seem to excel in loose stone, damp earth type stuff.
So far a 1000 miles has shown very little wear. Ideally we need some more rain to fully test them …………
As you know, I am a fastidious bar steward, and so far I am well pleased with the purchase ………… one word of caution (and this is not to be taken in the negative) if you do decide to deal with LA supertux …….. pm me wink.gif .
Ian
RocKeR
QUOTE (GBMUD @ Sep 12 2006, 02:27 PM) *
Chris, How much of this problem might be a function of the rim as opposed to the tyre? Or is this ingress of mud a known MT problem? Not something I've noticed on my 750 SAGs. tongue.gif
GBMUD
QUOTE (Bull Bar Cowboy @ Sep 12 2006, 04:09 PM) *
Thanks Ian. The one thing that would concern me most, given the look of the tyre tread and the number of road miles I do is wear. I do not want to wear them out and never get the benefit off-road. smile.gif They look a little pricey too. The size looks spot on however. Are you at FSWC? I will have to inspect them. smile.gif
Chris
GBMUD
QUOTE (RocKeR @ Sep 12 2006, 04:28 PM) *
I had BFG 265/75 MTs on the same rims before and NEVER had the same issue. The 255s are a newer design (with the side wall tread and, ironicly, the bead protector) and seem to suffer. I know that I am not alone in finding this.
Chris
tiddler
Hi G8MUD,
I used to have this problem nearly every time out when I ran 255 bfg KM's on steel modulars.
I have since used compomotive alloys and Mach 5's, neither of which have ever trapped stuff in the bead.
You are right that the Km's are worse at it than the old ones.
Stick with the BFG's, you know it makes sense!
Tid.
Bull Bar Cowboy
QUOTE (GBMUD @ Sep 12 2006, 04:31 PM) *
Chris
Yes ………… I’ll be there………. Now I’ve got the truck fixed I’ll post the cheque. wink.gif
I think the mileage that folk used to get from BFG’s is a thing of the past as the compound seems to have changed, with folk now reporting more normal mileages of 25 / 30K ish.
I have got Kumo AT’s on the jeep and they are a very hard compound …… looks like they will be good for 40K ( they get lots of M/way)………… the wranglers (OEM) only gave about 23K.
I checked with the stateside guys and they were getting 25K+ from a set of LTB’s on jeeps…….. so if they give me 20/25K then I’ll be happy.
Ian
BogMonster
I've had 265 BFG MTs on my 90 (and the same set of tyres and rims on the old 90) for about two years now with no problems with muck getting in to the bead. The wheels I'm using are Freestyle alloys, I wonder if it is a particular problem with the combination of BFGs and steel modulars?
nas90
Ian
[/quote]
I have Super Swampers on the Eagle which are getting a bit low, never realised that there is a dealer in UK, when I looked a few years ago it was difficult due to having to import yourself.
These might be a good option for Chris, although the Eagle is a bit twitchy on wet tarmac, maybe thats my right foot and 5.9 litres of V8!
I will pm you when I need some swampers, which I rate as exceptionally good off-road.
My current 255/85/16 BFG MT have the 'patented' rim guard moulded into the rubber. I have to say that these tyres have proven to be less susceptable to muck between the rim and tyre than any other tyre I have fitted to the NAS.
Dave
Bull Bar Cowboy
Dave,
I just something to watch out for if you order through them ……… it not actually a problem as such, but well warned is well armed ohmy.gif
Ian
TJ101
Mmm, think i am with rocker here, a rim problem, not tyre ,,, have ran Grizzys and BFG's
Had the same problem on the old defender, when running both disco steels, then wolf rims , but since changing to Mack's no trouble !!
Andy
i run machos on disco steels, i get the same problem with mud in the bead. id guess by the time my fronts die they will have done 20/25k, done 15k ish & about half worn. replaced the rears due to sidewall damage.
i like them, work well everywhere. but if you do slide them a lot on tarmac (they handle well when you do) they do wear rather quick.
Turbocharger
Don't Mach5's use the wheel cut from an 8-spoke or modular, and just weld in a new centre?
TomG
I run BFG MT 35/12.5/15 which have the rim guard thingy on deep dish (10" wide) white 8 spokes. air down to 15-18 psi offroad. Had them for over a year and only had 1 air leak due to dirt in sidewall.
Great floatation over the bogs, only complaint is that the sidewalls are bit too thin & fragile (a stump went through one recently sad.gif )
Mark
Chris,
I know adrian is having the same mud ingress problem on his rangie running machos on white 8 spokes.
I am running 255/75 BFG M/T's on disco steels and don't seem to have a problem - I know you are goung to say that I don't actually drive it offroad, but I do, honest tongue.gif
Not sure it is much help, but It would lead me to look at the rim rather than the tyre perhaps.
I have a set of disco steels here if you want to try them out?
Cheers
Mark
GBMUD
OK. I am not prepared to accept that the wheel is 100% to blame, too many other people seem to have difficulties with the new BFGs and my old style BFGs were just fine on the same rims. I will accept that the wheel is a factor in this though. Anyone think they can put their finger on where the problem lies? Is it the width of the tyre vs. the width of the rim - in this case a 7J?
Mark, I may accept your offer of the Disco rims on loan but I will need to borrow/steal/obtain some wheel spacers from somewhere to offer the same track as I get with the 8-spokes - partly as I like the way it looks and partly so that it is a fairer test. Meantime, I think I will try adding tubes to the two front tyres (the worst afflicted it seems) and see how they last puncture wise. I have a couple of greenlane and off-road trips coming up so we'll see.
Chris
BogMonster
My 265s are on 7Jx16 alloys.
SteveG
My 255/85 16 BFG MT's have now done just under 12000 miles since I put them on in November last year. In that time I reckon I've only done about 350 off-road miles, with at least 300 of that green laning.
I just measured the tread and front and back are just over 14mm. The new spare is 17mm.
What do we reckon is the minimum useable tread depth off-road before there's no point in using them??
If it's 8mm I've probably got another 24,000 miles in them, if 10mm then only about another 16000 miles.
Cheers
Steve
white90
Plus you now have a winch so you can let the wear down even more.
JST
Why Taffy?
Chris stick with the BFGs and try different rims, i run MTs on wolf rim (6.5J i think) and no problems with mud in the beads (OK once it was a problem but that was my fault)
Also although they wont look right if your doing so many road miles and towing alot ATs have alot going for them, trac edge woudl be ideal then.....
miketomcat
[quote name='GBMUD' date='Sep 12 2006, 02:27 PM' post='83404']
[*]I seem to tow quite a lot, although seldom VERY heavy trailers, the caravan at a little over a tonne is about the limit on a regular basis.
i run the 33"x12.50 machos on my tomcat road/off road grip is outstanding wear is acceptable no mud in rims and i tow all sorts of trailers from bike to 2ton exhbition with no probs i love them smile.gif
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
