QUOTE (BogMonster @ Sep 14 2006, 08:18 PM)
Well I think I will get them anyway, rusty bolts in alli panels doesn't do much for the panel in the long term either, and that is something I DO know...
Somebody needs to make a little sort of bolt condom that will wind in with the threads and keep the different metals isolated.
Coo I have just made my fortune - the BogMonsterBoltDom (patent applied for)
I've got anode, its just below and in front of my eyes
The boat people say that you shouldn't use copper grease in a salt water environment precisely because of the electrolytic reaction caused by the copper, which is interesting to bear in mind
Stephen
Someone is ahead of you on this one!
The product to use is called "Duralac" an anti-corrosivejointing compound.
It is a paste, and on the tube it says "used in the aerospace industry as an essential corrosion inhibiting material wherever dissimilar metals are joined"
Website
www.llewellyn-ryland.co.ukIt contains white spirit and barium chromate.
I use it when fixing items with stainless steel fastenings to the alloy mast of my yacht and on my rib where relevant. I know most "professional riggers" use it whenever they fix to alloy with S/S fittings/fixings.
John
