So I gave it a good wire brushing and then experimented with some of that 'Rust Eater'... I placed loads in the pump depression:
and left it there for 20 miutes - agitating it occasionally with a stiffish brush.
Then I removed it and - HEY PRESTO:
No difference. When I tried the same stuff on my CBR600 after a winter of commuting it was MARVELOUS... Bringing the fan motor upt to bright metal in no time! Ah well, I suppose Rover-Rust is just that much tougher to shift than Jap-Cr*p... Or maybe the stuff goes off?
Anyway - since it doesn't look like I'm going to be painting onto bright metal, but onto (well wire-brushed) rust: What would the panel recommend in terms of primer?
I have heard that Zinc Phosphate primer will stabilize rust and act as a good base coat, but an old friend once said that you can't beat 'red lead' (I think he may be a little too old!)
Any guidance/experiences would be appreciated.
Roger
