The gauge used is from a welding gas regulator - and they are only a few quid to buy new. The jack is a Draper 2 ton type and it cost all of £9.99.
The other two jacks I have are so similar that I would be confident just to drill in the same place.
The last two photos show lifting one of the rear wheels on my 90.
The piston in the jack is 21.9mm in diameter or 0.584 sq inch area.
It therefore takes 3.78psi to lift 1kg
Thus the 2400psi shown equates to 634kg - which is about right for the weight of one corner.
I'll probably go and weigh the back end on a weigh-bridge to calibrate it more accurately.
Si
