Help - Search - Members - Calendar
Full Version: Chain onto ratchet straps
LR4x4 - The Land Rover Forum > The Lounge > Tools and Fabrication
nige90
Hi all,
I need to find ratchet straps with fittings that 10mm chain can link into
instead of the usual D Rings or cargo hooks. Sort of thing used on the
A Frames the AA use.
I'm imagining something with a T slot to catch the chain links.
Anyone know of suppliers ?
Thanks
Nige
Glue
Try contacting your local lifting gear stockist. They should be able to sell you all the links and bits to build your own. The only sticking point may be that they won't sell to you if they find out you want to attach a chain sling (which is rated for lifting) to a ratchet strap (that isn't). If so then try elsewhere and don't tell them why you want the bits.
HTH
Glue
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2008 Invision Power Services, Inc.
