Simon_CSK Posted December 28, 2016 Share Posted December 28, 2016 Can anyone tell me if the inlet manifold, to bit that bolts to the engine in the valley, is the same on a GEMS and a Thor. I have a GEMS block which I am fitting into a Thor car so it would save me a job. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 28, 2016 Share Posted December 28, 2016 Nige should be able to give you the definitive on that but I think they're basically the same casting, albeit with detail differences. Probably depends which direction you're going. Quote Link to comment Share on other sites More sharing options...
elbekko Posted December 29, 2016 Share Posted December 29, 2016 They're a bit different IIRC. Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted December 29, 2016 Author Share Posted December 29, 2016 Yes definitely different unfortunately. Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted December 29, 2016 Author Share Posted December 29, 2016 On 12/28/2016 at 10:56 PM, FridgeFreezer said: Nige should be able to give you the definitive on that but I think they're basically the same casting, albeit with detail differences. Probably depends which direction you're going. The bolting configuration is completely different on the top side and the cooling piping is different. Was hoping to keep the GEMS one on however when I started to strip it there were injectors for the LPg system that I had forgotten about. I also realised today that this block has been in 4 cars GEMs first then I bought it to go in a Thor then I put it in a GEMs and now going back to Thor. You would think I would know by now what can go where. Quote Link to comment Share on other sites More sharing options...
