TD5 Nanocom Error Code
V8 Freak
Wondering if the knowledge of those on here might help me....
I was doing some work on the truck today and read the faults on my ECU.
Got this one...
8-1 air conditioning fan drive over temperature (logged)
I cleared the code and it registered again when I ran the engine.
I've not had time for further investigation and intend checking the condenser fan itself...
Any other suggestions of things I should consider?
Anyone had this code themselves?
Thanks in advance
Neil
You can test the condenser fan using the Nanocom - I cannot remember where it is but I found it while playing around with it. I also have this error code up all the time and like you I clear it and it comes back every time the engine is started. I seem to recal that other defenders that I have plugged into also have this error code up.
