The Badger Posted January 14, 2017 Share Posted January 14, 2017 So, it's a bit of a weird one and I "think" i know what is wrong, but... After running the Defender for a while, if I turn of the engine, it will not start again. I turn the key and on crank, I get nothing. I "think", its the starter motor solenoid or motor being too hot from the engine. It will start if I let it cool down a bit? Anyhow, anyone had such issues? Cheers Quote Link to comment Share on other sites More sharing options...
qwakers Posted January 14, 2017 Share Posted January 14, 2017 is the heatsheild missing (200tdi and im sure the 300 tdi would have one too, but knowing what engine it is would help ) Quote Link to comment Share on other sites More sharing options...
The Badger Posted January 14, 2017 Author Share Posted January 14, 2017 (edited) Yes. where should it be? sorry it's a 2.8 Tgv, mostly like a 300tdi Edited January 14, 2017 by The Badger Quote Link to comment Share on other sites More sharing options...
qwakers Posted January 14, 2017 Share Posted January 14, 2017 on my 200tdi it was bolted to the starter motor completely covering it from view. Quote Link to comment Share on other sites More sharing options...
kevh Posted January 15, 2017 Share Posted January 15, 2017 Is it cranking fast enough when hot? Have you checked for fuel at inj pipe? maybe try removing plunger from stop solenoid in pump,although you will need to stall it when it has started. Process of elimination i'm afraid, Good luck Quote Link to comment Share on other sites More sharing options...
