reb78 Posted January 16, 2017 Share Posted January 16, 2017 Does anyone know if the body parts associated with the fuel filler on a 110 can be bought separately? I am looking to design and fit a second diesel tank in the passenger side rear quarter panel/wheel arch space and, if possible, would like to replicate the look of the body around the filler as it appears on the driver side of the 110. I've had a look on LRCAT, but cant find the parts - may be looking in the wrong place though. Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted January 17, 2017 Share Posted January 17, 2017 I knew I'd seen this somewhere.... http://www.yrm-metal-solutions.co.uk/epages/BT4822.sf/en_GB/?ObjectPath=/Shops/BT4822/Products/262 I made mine from scratch to fit onto my new quarter....if you're mirroring the OE aperture then you should be able to cut from a template and form the small radius with a hammer and dolly. I toyed with fitting a hi-cap aperture but it sat the filler neck at the wrong angle however that may not be an issue for an auxiliary tank. This just needs the hole cut and the plastic aperture screws on. Even went as far buying the parts... Quote Link to comment Share on other sites More sharing options...
reb78 Posted January 17, 2017 Author Share Posted January 17, 2017 Perfect! Thanks! I need to make this more than a vapour build now. Going to contact a professional welder i know near me to chat about making the tank. Quote Link to comment Share on other sites More sharing options...
western Posted January 17, 2017 Share Posted January 17, 2017 only in parts links as part of the right hand rear lower body, regardless if left or right hand drive item 2 in http://www.albrit.de/UNI.cfm?PAGE=765066&SPRACHE=EN Quote Link to comment Share on other sites More sharing options...
reb78 Posted January 17, 2017 Author Share Posted January 17, 2017 Thanks Ralph. Thats all I could find as well, but I think the part that Scott has linked to will do the job. Quote Link to comment Share on other sites More sharing options...
western Posted January 17, 2017 Share Posted January 17, 2017 Reckon the YRM part will be spot on for the job you've got lined up. Quote Link to comment Share on other sites More sharing options...
