Audi vnt turbo on 300tdi
Hi all,
I am thinking of putting a vnt turbo on my discovery 300tdi engine.
I would like to put a Garrett GT2052V turbo from an Audi A6 2,5 v6 engine. I heard these turbo's can be used on land rover engine with some adjusting?
Has anyone ever (successfully) put a turbo like that on a 300tdi engine? What modifications are necessary?
I heard a discovery 200tdi exhaust manifold could be plug and play?
Thanks!
The audi will have had an electronic control system with a solenoid in the system before the (pressure) actuator. My 1.9tdi certainly does. Don't forget that it uses the vanes for boost control, not just to improve the spool at low end with what essentially amounts to variable A/R (there is no waste gate), and I suspect a non linear relationship between boost and ideal vane position, or there would be little point in the control system.
I've seen a few people claim to have done VNT conversions, but none with any technical detail beyond a scant "oh, slap on this actuator that happens to fit. Works great" that leaves you wondering if it really works that well, or even better than what was there originally....
Don't let me put you off, I think this would be a great project if done well (more than bolting it up and hoping for the best). Looks like that garret has a good shot at bolting up to the 200tdi manifold - certainly the same shape. Order up a gasket from each to check?
Those audi turbos are plentiful and cheap. Controlling it to get the best out of it is the real challenge, though.
Ian
No, that is not quite right.  They use vacuum control.  The vanes are open until boost is desired, it then closes them as much as possible to achieve the requested boost.  It is nothing complicated.
You can use a simple direct pressure actuator just like the 2.8.  It works fine.  You lose some efficiency when off boost, but I doubt it is measurable.
Hello,
The turbo's i am looking at are vacuum controlled.
Will have a look into the iveco turbo's as the audi turbo only fits with a defender 200Tdi exhaust manifold apparantly.
https://plus.google.com/photos/112012783108056418001/albums/5434753789820442705?banner=pwa#photos/112012783108056418001/albums/5434753789820442705
Thanks!
19 hours ago, thibauts said:
Hello,
Thanks!
You got me looking at this - and it does look like the audi would fit the defender manifold, but the position of the actuator would make it too high to close the bonnet by the look of it.
How easy would it be to relocate the actuator? Also, hopefully relevant to this thread, I had assumed the stock 200tdi turbo is pressure actuated. So whats involved in converting a vacuum operated turbo to a pressure actuated one? Just changing the actuator?
That's not what I'd heard, I was under the impression the geometry was a bit more complex and there was a risk of stalling the compressor in certain configurations. The TGV 2.8 works OK with a dumb actuator but is by no means perfect.
Most I've seen use a PWM controlled solenoid the vary vacuum on the actuator, a controller would be the work of moments with a small microcontroller board and a driver circuit connected to a PWM pin. The hard part would be mapping the required boost/geometry across the load/revs/throttle range.
The TD4 Freelander uses the PWM solenoid method, the same part# actuates the EGR valve and crops up on TD5's too so an easy pick from the parts bin.
Not with a diesel.  They are complicated to control on a petrol.  Diesel control is very basic.
Would this be as simple as measure MAP, RPM and throttle position, when the pedal is in a low demand position and engine near idle set the boost control to allow it to spin up easily, show some pedal and then just move actuator to give max boost - beyond maximum boost start to move the actuator back to maintain maximum. As said above that would be easy to code (I think) ?
I looked at a 4cyl BMW turbo setup and whilst post EU4 they used an electric actuator before that the same setup just appears to use a vac boost actuator controlled by a vac switch giving none proportional on/off control. (edit) thinking about that it seems wrong as I cant see any method of progressively limiting boost such as a wastegate
21 hours ago, Red90 said:
That version seems to have the wrong manifold flange.
Nothing a bit of 10mm plate wont fix, otherwise an Iveco  2060V has the same flange but uses studs so either the manifold or the turbo will need to be drill out.
  • 8 months later...
After a little research I've come up with some ramblings, as I understand it there are two simple-ish ways to do this.
Either using a turbo controller such as a Digibooster, the kit all in is £165.
Or convert to boost controlled, I found some universal boost actuators online which come with a selection of springs which would be useful to tune the vanes since I can't find anyone that has fitted an "off the shelf" actuator. The actuators are around £70
That's worth knowing!
Someone told me that you can swap the actuator and use the standard tsi item with a bit of fettling. Not sure if this has even been done to prove the theory though
  • 2 years later...
  • 5 months later...
  • 1 month later...
On 8/2/2020 at 7:12 PM, GORI V8 said:
Hi, did anyone end up using a GT2052V in the end? I am about to go this way.
I’m currently going this way as I already had a gt2052v in going with a universal waste gate controller with different spring pressure and mounting the actuator on the opposite side to push vanes open rather than pull hope this helps
Very interested to see the results.
