ashleyb Posted January 25, 2017 Share Posted January 25, 2017 Hi all,the level/filler plug for the swivel housing on my recently purchased series 3 has got rounded off,until i weld a nut on it to hopefully get a larger spanner on it,is it possible to fill the oil from the top of the housing by removing any parts to gain access.Any ideas much appreciated Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 25, 2017 Share Posted January 25, 2017 The only other place you could fill it is by removing one of the top pin bolts (they are tapped right through). Les. Quote Link to comment Share on other sites More sharing options...
ashleyb Posted January 26, 2017 Author Share Posted January 26, 2017 23 hours ago, Les Henson said: The only other place you could fill it is by removing one of the top pin bolts (they are tapped right through). Les. Many thanks I,ll give this a go Quote Link to comment Share on other sites More sharing options...
neil110 Posted February 5, 2017 Share Posted February 5, 2017 Of course you could always use a set of stilsons on the existing plug, presuming you can get a set in there. Yes I know it is a bit of a gorilla solution but it might save you having to weld a nut on the plug. Quote Link to comment Share on other sites More sharing options...
Snagger Posted February 5, 2017 Share Posted February 5, 2017 You could also try grinding new flats onto the plug (and then fit a new one once removed). The heat and vibration from the grinding may help with the rusty threads, too. Quote Link to comment Share on other sites More sharing options...
