IanT90 Posted February 2, 2017 Share Posted February 2, 2017 I have oil leaks from both prop shafts so planning to replace both flanges and seals in coming months. Watched a couple of videos recently and a common trick/technique for removing the seal is to drill a hole (or 2), then screw a self tapper in and use it to pull the seal out. I was wondering, never having done one before, can you use a puller by fitting it in the gap between oil seal and pinion shaft and use that to extract it ? Not sure if there is sufficient space to get the puller legs in ? Or is there a better way ? Quote Link to comment Share on other sites More sharing options...
Dave W Posted February 3, 2017 Share Posted February 3, 2017 A normal seal puller tool will do the job or, if you haven't got one of them it can normally be levered out using a screwdriver, spanner or small pry bar. There's plenty of room to get in around the pinion and get your levering tool between the pinion bearing and the back of the seal. Some people just over think these things ! Quote Link to comment Share on other sites More sharing options...
Snagger Posted February 3, 2017 Share Posted February 3, 2017 I just use a screwdriver to lever it out. Drilling a hole to put in a screw will just introduce swaft and debris intot he pinion bearing and is completely unnecessary. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 3, 2017 Share Posted February 3, 2017 You only need to do the screw method/use a proper extractor if the casting is aluminium, or the shaft is in the way. A big screw driver and away it goes... Quote Link to comment Share on other sites More sharing options...
IanT90 Posted February 3, 2017 Author Share Posted February 3, 2017 Thought the screw method was a bit over kill, I have used a screw driver to lever oil seals out before. Fortunately I have 2 pullers - a 2 prong and 3 prong so spoilt for choice there. Obviously the guy's in the videos either don't have pullers or just like over complicating the job ! Cheers guy's Quote Link to comment Share on other sites More sharing options...
