Sign in to follow this
Followers 0
Chambo110
Handbrake light switch/wiring
8 posts in this topic
Another question off the back of my tbox change.
i don't seem to have a handbrake warning light on dash anymore . It's an 87 110 csw. With 200tdi.
Checked under handbrake gaitor . Don't remember moving anything ?? But what makes the light come on if I have no switch on hbrake lever or any visible wiring ??
confused how it works.
i do have a stray blue wire coming straight from battery but who knows where that goes ? Could that of been doing something ?
thanks
Share this post
Link to post
Go to our Tech Archive index & in the electrical section scroll to
'park brake warning light'
a post I wrote ages ago October 23, 2005 of how I fitted one to my '89 110 using genuine parts & a homemade ramp for the bottom of hand brake lever
Share this post
Link to post
Sorry I'm late. I did read the post ref the handbrake switch , might give it a go.
any ideas what's wrong with my original set up though. Could the blue wire hanging down direct from battery + be something? I had dash lights before but nothing now?? Strange ?
Share this post
Link to post
Handbrake from original wiring was a yellow wire, onto the switch tacked onto the side of the handbrake. You'll have a pair of wires for the diff lock switch (black/blue and black) and another pair for the reverse light (green & green/brown). If it was "standard" wiring there shouldn't be a blue down there.
The handbrake wire operates a switched earth, so may be worth checking with a multimeter or test lamp to see if your blue wire has got power....you could of course be highly unscientific and Earth the blue wire and see if your handbrake warning light illuminates! Worst case scenario you'll pop a fuse :rolleyes::ph34r:
Share this post
Link to post
Blue wire comes straight from battery? I've taken it off now. I'm sure something will come to light ( or not) that will point out what it was for
as for the handbrake switch.. I don't have one it's just the lever, no sign of any yellow wire.
will eventually do westerns " park brake switch " upgrade
diff lock and reverse now sorted , although reverse is someone else's bodge that I will eventually sort .
keep ya busy these things don't they 😂
Share this post
Link to post
Blue wire must be an extra from a previous owner. From memory battery power feeds to the starter motor/alternator then loops around the back of the block with two 4mm2 brown cables to feed into the fuse box and bulkhead loom.
1 person likes this
Share this post
Link to post
Nice one thanks. I guessed it may be something previous owner did.
still baffled to know how my park brake lights were working though ??
Share this post
Link to post
Ok so not wiring related, but still handbrake...
when I changed transfer box I changed bits inside handbrake drum, expander etc.
but first test drive, all seems great, no leaks, gears all fine but I get a noise when moving like something is intermittently rubbing on drum, if I lift handbrake 1 or 2 clicks it goes away, so I tightened the adjuster a small turn . But drum gets hot. I'm guessing it shouldn't?? Not red hot . But enough to make me jump. Wasn't along drive. Just around the block
any of you guys think what I may have done wrong ... or right ??
cheers
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
