Bandog Posted February 16, 2017 Share Posted February 16, 2017 Earth blocks from toolstation. For pence. Plated brass, solves where to put all earth leads. I have put these on both rear light pods, and under the dash. Quote Link to comment Share on other sites More sharing options...
simonr Posted February 16, 2017 Share Posted February 16, 2017 I've used quite a lot of these! I've attached CAD files for 3D Printed shrouds to insulate the blocks. They have a way-higher current rating than most connectors. I've used Pin type crimp connectors to terminate the wires and clamped them in the holes, much like a connector block. They've proven reliable even in a moist Defender over long periods. Connector Block Lower.STL Connector Block Upper.STL Connector Block.STEP 1 Quote Link to comment Share on other sites More sharing options...
Bandog Posted February 16, 2017 Author Share Posted February 16, 2017 Excellent. Is it me,or am I now seeing much brighter lights now that the earth's are sound? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 16, 2017 Share Posted February 16, 2017 Can only help.... Quote Link to comment Share on other sites More sharing options...
DaveSIIA Posted February 18, 2017 Share Posted February 18, 2017 Tinning the ends of the wires and screw in to the block would improve long term reliability. Quote Link to comment Share on other sites More sharing options...
davie Posted February 19, 2017 Share Posted February 19, 2017 As somebody much wiser on wiring than me always reminds me, never good practice to see bare copper wire like that, trim end to fit connector and perhaps heat shrink to make tidy. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 19, 2017 Share Posted February 19, 2017 Great idea, slightly iffy execution then, I guess Quote Link to comment Share on other sites More sharing options...
Bandog Posted February 19, 2017 Author Share Posted February 19, 2017 Quote Earth wires it doesn't matter at all. The live feeds are all insulated Quote Link to comment Share on other sites More sharing options...
Peaklander Posted February 19, 2017 Share Posted February 19, 2017 It not some much that you are protecting the conductor from shorting somewhere, it's more that you should try to prevent ingress of moisture to any connection. In this case the crimp itself. Quote Link to comment Share on other sites More sharing options...
Bandog Posted February 19, 2017 Author Share Posted February 19, 2017 That's why we put tiger seal in the inlet cable hole in the tub. I will put spray grease on the whole thing Quote Link to comment Share on other sites More sharing options...
WesBrooks Posted February 21, 2017 Share Posted February 21, 2017 On 02/18/2017 at 0:47 PM, DaveSIIA said: Tinning the ends of the wires and screw in to the block would improve long term reliability. Don't tin, use crimp on ferruls as in the following link. Tinning screw terminals is not great for long term reliability. I used to tin for neatness too. http://electronics.stackexchange.com/questions/29861/tinning-wires-that-will-be-screwed-in-to-a-chocolate-block-terminal-strip Quote Link to comment Share on other sites More sharing options...
Bandog Posted February 21, 2017 Author Share Posted February 21, 2017 I would put weetabix on it, just for a silly response mate Quote Link to comment Share on other sites More sharing options...
