Dave P
Bush to hold gear knob on
6 posts in this topic
Does anyone have any ideas where I can get a steel corugated bush that can be used to hold the gear knob on. My gear stick has no threads on its end
cheers Dave P
Share this post
Link to post
that bush is part of the gear knob, the knob screws on to the lever thread
Share this post
Link to post
I replaced mine with an M10 Riv-nut.  It expanded into the plastic - and stuck good!
Si
Share this post
Link to post
I filled the gear knob on my LT95 with glue from a glue gun and after it cooled, drilled it to about the right size and screwed it on. It's lasted longer than the new Genuine Part did!
Share this post
Link to post
I turned and tapped an alloy bush then glued it in with JB weld, perfect.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
