eastw77 Posted February 18, 2017 Share Posted February 18, 2017 Has anybody tried one of theses distributor condom thingies?? Do they work or is it as bit of a gimmick? http://www.rimmerbros.co.uk/Item--i-GDC117BMWPKIT Quote Link to comment Share on other sites More sharing options...
Landrovernuts Posted February 18, 2017 Share Posted February 18, 2017 I found them a waste of time as they used to leak/sweat and then not being able to breath made things worse. I found a decent cap sealed with a smidge of silicon grease and a good set of leads was the best cure. At one point I made a small cover which bolted from one of the water pump bolts and somewhere else (memory failing!) made a difference to as it kept most of the spray from the fan away. Toby Quote Link to comment Share on other sites More sharing options...
zardos Posted February 18, 2017 Share Posted February 18, 2017 I had a few of then and they worked fairly well in medium deep water (but not over the dizzy deep) to keep the dizzy dry from splashes, but they did like to degrade over time and stick to the dizzy due to the heat under the bonnet of a V8. But you also needed good HT leads for medium deep water wading. Quote Link to comment Share on other sites More sharing options...
eastw77 Posted February 19, 2017 Author Share Posted February 19, 2017 Thanks guys... Ill maybe give one a go and see for myself. Quote Link to comment Share on other sites More sharing options...
