Bandog Posted February 20, 2017 Share Posted February 20, 2017 (edited) Wondering where this goes? It's not the side light connection, it goes up into the column switch, with hi lo lights, horn, indicators. The haynes manual I have does not suggest any green with red going there at all, so completely baffled? Thanks Edited February 20, 2017 by Bandog Quote Link to comment Share on other sites More sharing options...
jordan_meakin Posted February 20, 2017 Share Posted February 20, 2017 Is it for hazard lights? Optional extra on later models on like a pull nob. Usually mounted in the centre though... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 21, 2017 Share Posted February 21, 2017 Being pedantic that looks a lot like light green (LG), which is a different thing than green (G) in the wiring diagram. Also possibly pink not red, hard to tell. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 21, 2017 Share Posted February 21, 2017 This is handy: http://www.expeditionlandrover.info/Lucaswirecode.htm Something to do with 'fuel mixture light to fuel mixture thermostat switch (vech. with carb heater)' if a light green/red or 'Direction indicator switch to left-hand flasher lamps'. Not always definitive, but can be a good push in the right direction. Quote Link to comment Share on other sites More sharing options...
Bandog Posted February 21, 2017 Author Share Posted February 21, 2017 Thanks. Got a feeling it's for the indicators Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 21, 2017 Share Posted February 21, 2017 IIRC Green/red and green/white are indicators, could be for a hazard warning switch. Quote Link to comment Share on other sites More sharing options...
Bandog Posted February 21, 2017 Author Share Posted February 21, 2017 It goes to both the left and right indicator Quote Link to comment Share on other sites More sharing options...
Ex Member Posted February 21, 2017 Share Posted February 21, 2017 What year are we talking about? Can help you find the genuine wiring diagram. Quote Link to comment Share on other sites More sharing options...
Bandog Posted February 21, 2017 Author Share Posted February 21, 2017 (edited) It's a britpart I think mate. It's a hybrid, so no telling. The stalk is definitely a replacement, on a series 3 column Edited February 21, 2017 by Bandog Quote Link to comment Share on other sites More sharing options...
Ex Member Posted February 21, 2017 Share Posted February 21, 2017 (edited) Okay, then I'm not sure how anyone on the internet will be able to tell you where the wire goes if there is no way to know the origin of the wiring loom. You will need to trace it yourself. As above, the colours are not clear in your photo. Green-red is left turn signal. Light Green - Purple is trailer warning light. That is all I can see that is close. Edited February 21, 2017 by Red90 Quote Link to comment Share on other sites More sharing options...
