trod Posted February 28, 2017 Share Posted February 28, 2017 Hi ,can any one tell me where the drain pipes for the sun roofs come out and how to Get to Them so that i can blow them out from the bottom. Thanks Trod Quote Link to comment Share on other sites More sharing options...
teabag Posted February 28, 2017 Share Posted February 28, 2017 There's only two drains at the front one at each corner of the sunroof, for the front they are within A pillar and not accessible, for the rear the ends can be seen hanging down at the rear and up above the each mudflap on a D1 so should be similar on a D2. Why do you think you will have to blow them out? They are sealed nothing can get in when the glass is closed. Quote Link to comment Share on other sites More sharing options...
bear Posted February 28, 2017 Share Posted February 28, 2017 Hi Trod, You don't say which vehicle you have - D2 rear drain pipes are behind the rear upper light clusters. Front are well hidden below the A pilar as stated. Usually covered in mud so need a good poke around. HTH, Griff Quote Link to comment Share on other sites More sharing options...
trod Posted February 28, 2017 Author Share Posted February 28, 2017 Thanks i will have a look in the morning Quote Link to comment Share on other sites More sharing options...
