SalM Posted March 13, 2017 Share Posted March 13, 2017 Hi, I'm new to this, so apologies if this has been asked before! I have a 2012 Freelander 2 GS TD4 Manuel and it has suddenly, without any warning, lost all power. In any gear, I can put my foot flat down on the accelerator and it can't get past 40 MPH and that is a struggle. Does this mean that the Turbo has gone and approx. how much will this cost to put right? Many thanks Quote Link to comment Share on other sites More sharing options...
Dorsetfreelander Posted March 13, 2017 Share Posted March 13, 2017 Hard to say at this stage but have a look at this for a start Quote Link to comment Share on other sites More sharing options...
LRNZ Posted March 18, 2017 Share Posted March 18, 2017 I had a similar problem and it was the electric fuel pump that had failed. The car would loose power going up steep hills etc. The check engine light would come on when accelerating and then clear when foot lifted off accelerator. If the check engine light is coming on at same time, you should be able to read the fault code. cheers and good luck Quote Link to comment Share on other sites More sharing options...
caiocsa Posted March 28, 2017 Share Posted March 28, 2017 I guess that could be a leaking pipe in the turbo system! Quote Link to comment Share on other sites More sharing options...
