Fitting 4.0 Thor into a 90
Hi all, Thinking of fitting a 4.0 V8 Thor engine out of 1 of my P38's into my 90 which is currently fitted with a 3.5. I see that Devon 4X4 have done it to one of there project motors. Would any of you guys happen to know if it's easy enough to do with the wiring ect ect.
thanks in advance
Had my old 90 converted to a gem V8 by a friend/business but took ages.
One thing to consider is if fitting Auto box contact Ashcroft for there controller as is very simple to set up and allows for gearbox modes to be adjusted simply.
It's easy enough but I'd really recommend going Megasquirt for the EFI, Nigel at Megasquirt-v8 (hybrid_from_hell on here) is the man and his kits are luvverly. Way nicer to use Nige's wiring kit and built the (much simpler) loom in-situ than try to shoehorn an octopus from a P38 into a Defender.
My 4.6-into-127 write-up starts about here:
Done it on the 109 too but that's less relevant.
