Hercu
Disco 1 front Propshaft Phasing
11 posts in this topic
Need some help with Phasing
I had a double cardan fitted after lifting the disco 2''. It worked well and no vibrations experienced.
The universals got worn and serious vibrations on torque, and I have sent it to the nearest Propshaft centre (400 km away) and these guys decided to remove the Cardan and fit a wide angle yoke, Somewhere the message was lost....!!!!
With the cost and distance, my hands were cut and needed to except this "FU".
I am a week away from my anual holidays and plan a fishing trip wich involves  beach driving launching the jet ski.The road also demands heavy 4 x 4.
Phasing or out phasing will help for this trip... I see 22.5 degrees is the norm but very vague on what direction, meaning plus or minus from drive side.
Do I advance 22.5 deg or reverse. (1 spline or 2 splines)????
Share this post
Link to post
I'm embarrassed,  I've just gone through my hard copy of the workshop manual and while it shows the front propshaft offset it fails to give a quantum.
 When one Universal joint is horizontal and vertical the other one in the drawing appears to be at roughly 45' to it, if you say thats 22.5 degrees I have no way of doubting you but it does seem to be greater than that and the figure of 30 degrees is in my mind from somewhere. As for which end I dont think it matters so long as the shaft has been balanced as the off-set is purely to give greater flexibility on the front suspension. .
Share this post
Link to post
Hi Boydi and Red.. Thank you for the reply's
Boydi yes, It is a preference thing and trial and error is the best way to do...
I worked on splines and counted ........ 16 x 22.5 = 360ᵒ
I notched mine at 2 (45ᵒ) splines out of phase with the T/Case universal leading and had a heavy load drive without vibration but a seious whine from 40 kph to 110 kph + on the pull.
Red,  I have read the mentioned post, wrote my thread, and read the post again and eventaually got the hang of it... Thank you...
( Sorry for late Feedback but had a wonderfull weekend fishing )
One lesson learned, I will never lift a vehicle again...Go for bigger tires and rims, do the camel cut yes, but a body lift is a waste and nothing to gain... just a lot off other geometrical problems. The Diff clearance stays exactly the same...!!!
Share this post
Link to post
Welcome to the Land Rover learning curve 😊
Mo
1 person likes this
Share this post
Link to post
Thanks Mo,
Yup.... and an empty wallet but I love my Landy...!!
In South Africa the Currency is Rand ....Change the L and R in Land Rover and you get ...Rand Lover...!!
Share this post
Link to post
A double cardan is only required for over 3" lifts, overkill for 2".
Share this post
Link to post
On the subject of UJ's and propshafts, any ideas why the TDi gets a rubber coupling on the rear propshaft, but the V8 has a proper UJ (D1) ?
Surely it couldn't have been a cost saving exercise ?
Share this post
Link to post
Totally excepted, but very nice to have.....!
Share this post
Link to post
Surely not a saving,,,I chucked mine very early in my TDi 1 Land Rover ownership...Fitted proper UJ's
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
