Cabs, rooves, doors.
doors will fit if you use the correct lock striker on the door pillar, roof would but only with the matching series LR windscreen frame. a backward step as the 90 screen is much taller & gives a better road view forward.
  • Like 1
Are you sure about the roof because I'm pretty sure the sides don't fit a 90. 110/109 I believe will. 88 sides fit a 110sw but 90 sides don't. Truck cab should fit but as western says with a series windscreen.
Mike
Edited by miketomcat
  • Like 1
The 88" roof will not fit a 90 - sorry, we tried.
The 88" side panels will not fit a 90 - sorry, we tried.
The 88" side panels will fit a 110 SW - we tried.
The 109" roof will fit a 110 if the Series windscreen is fitted - we had it like that some time ago..
The doors, as mentioned, are the same dimensions but will at times need other striker plates.
Edited by Arjan
  • Like 1
