Paddy_SP Posted April 18, 2017 Share Posted April 18, 2017 My Defender (200Tdi 110) has been off the road for so long that now I've got to make up some new fuel lines, I can't remember which way around they go onto the tank... It has two fittings which are both 8mm - one in the centre (ish) on the main pump, while the other is on the side. Now it would make sense to me if the central one was the feed, and the other the return, but the only diagram I've been able to find shows it being the other way around - I'm therefore more than a little confused and would appreciate some guidance! Quote Link to comment Share on other sites More sharing options...
western Posted April 18, 2017 Share Posted April 18, 2017 TD & 200/300Tdi 110 diesel factory standard tank connections are top centre of tank is the spill return line, fuel feed to lift pump is on the sender unit left hand side, the short stub on right upper corner is blanked off not required or used. Quote Link to comment Share on other sites More sharing options...
Paddy_SP Posted April 18, 2017 Author Share Posted April 18, 2017 Once again, I humbly thank you for your help - it is much appreciated! 1 Quote Link to comment Share on other sites More sharing options...
western Posted April 18, 2017 Share Posted April 18, 2017 your welcome, it's handy having my 110 sat outside & having recently replaced the fuel tank, the info is still fresh in my head Quote Link to comment Share on other sites More sharing options...
